February 19, 2023 at 8:31 pm
Arkadiusz Adamczyk
Subscriberhi,
afrer I've validated the project, I am unable to analyze it. The following message pops out:
Unable to locate or start COM engine on "Local Machine" : unable to create engine process.
Could You helo mi out with this?
Arek
February 27, 2023 at 4:25 pm
ANSYS_MMadore
Forum ModeratorAre you trying to run the job locally or across multiple machines? Can you try disabling your firewalls to see if that is causing the behavior?
- The topic ‘Unable to locate or start COM engine on “Local Machine” : unable to create engin’ is closed to new replies.
