September 10, 2020 at 2:36 pm
Fremol
SubscriberI can't open projects done by old version using current version of ANSYS 2020 R1.
Here is the screen shoot:
Any ideas/help appreciated!
September 10, 2020 at 11:30 pmtsiriaks
Ansys EmployeeWhat if you move the project to be under C:\Temp and try again ?nMake sure you have its corresponding project folder under the same directorynSeptember 11, 2020 at 1:06 pmSeptember 11, 2020 at 9:58 pmtsiriaks
Ansys EmployeeIf you use this exact .wbpj file and project folder with old version now, does it work ?nDo you have other projects that you can try opening with 2020 R1 ? Do they have the same issue ?nSeptember 14, 2020 at 3:42 amFremol
Subscriber@ tsiriaks,nUnder C:\Temp: the project works with ANSYS 19.2 but not with 2020 R1.nOther projects previously done by ANSYS 19.2 can be opened by 2020 R1.nThank you,nSeptember 17, 2020 at 8:19 pmtsiriaks
Ansys EmployeeI see. So there is something specific to this project that can't be migrated to the new version.nI would recommend to create another post under this sectionnArrayand describe what you have in this Workbench project and if applicable, show the screenshot of your Workbench schematic for this project (of course when open with 19.2)nSeptember 19, 2020 at 12:19 pmFremol
SubscriberThanks tsiriaks! nI will create new post.nSeptember 21, 2020 at 9:55 pmtsiriaks
Ansys Employeesounds good.nThank you.nViewing 7 reply threads- The topic ‘unable to load project in ANSYS’ is closed to new replies.
4673
1555
1386
1230
