November 15, 2022 at 8:09 pm
Lorraine Olson
SubscriberI am using Solidworks 2022-2023 and have created a basic part, saved as a SLDPRT. Â When I use workbench and Geometry -> Import Geometry I get a green check mark, but when I double-click to open the geometry I get "Unable to import the specified geometry into SpaceClaim. Input file version not supported."Â
I tried the solidworks "save as Parasolid" V30 fix I found in these posts, but that is an unsatisfying solution for software that costs this much. Â
Even though I am a professor at a engineering school that pays a lot of money for this software, they now tell me that I am not entitled to support beyond posting questions on this forum. Â Also unsatisfying.
November 16, 2022 at 5:43 am
Keyur Kanade
Ansys EmployeePlease use latest version 2022R2 for SpaceClaim. Please check the latest version of solid works and parasolid supported by SpaceClaim in the help manual.Â
Go to File - SpaceClaim options - File options - Workbench and use 'Always use SpaceCLaim's reader when possible'.Â
Keyur
November 16, 2022 at 3:02 pm
Lorraine Olson
SubscriberOn 2022/R1: I tried
Then I tried to import the file, but it did not solve the problem.
I am working on getting 2022/R2 and will report back when I have tried that version.
November 16, 2022 at 5:41 pm
Lorraine Olson
SubscriberUpdate: 2022/R2 works fine, so apparently the bug was fixed in R2, but existed in R1.
- The topic ‘Unable to import the specified geometry into SpaceClaim’ is closed to new replies.
- Add-in Error Excel
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
- Inconsistent Script
- MISSING SIMULATION SECTION/RIBBONTAP
4613
1520
1386
1209
