September 27, 2023 at 12:32 pm
September 29, 2023 at 10:14 am
Sampat Kumar
Ansys EmployeeHi Daniel,
It appears that the unsupported file is the cause of the issue. Could you use SpaceClaim to open this geometry file? If so, save it to a scdoc file and open it in the WB later. Would you kindly provide further information regarding the file's issue? How and where did you import into the WB?Â
Sampat -
October 5, 2023 at 3:59 pm
Asumile Silas Mwakibinga
SubscriberHello, I am having a similar issue with scdoc files. I have successfully created scdoc files in SpaceClaim from stl files. The problem comes when I try to open the scdoc files in Discovery. Each one gives an "error loading file" even though there were created in SpaceClaim and can be opened in SpaceClaim without any problem. Please could you assist in this matter?
Thanks.
October 6, 2023 at 8:51 am
Sampat Kumar
Ansys EmployeeHi Asumile,
Please see the following Ansys forum thread and let me know if it solved your problem or not.Â
/forum/forums/topic/ansys-discovery-error-loading-file/
Sampat
- The topic ‘Unable to import spaceclaim model onto workbench’ is closed to new replies.
6625
1312
