Ansys Products
Ansys Products
Unable to Import Mentor Xpedetion ODB++ File into SIWave
    • Glenn Galea
      I've imported an ODB++ file from Xpedition into SI Wave before, however it seems that now it is throwing an error.
      Whenver I try to import a file, it throws an error and tells me to look at the ODBpp_translation log file.
      When I open that file, I see the follwoing inside
      Output: C:/Users/c1026938/AppData/Local/Temp/ODBpp.aedb
      Translation Start: Wed Apr 19 09:48:15 2023
      ODB++ translation
      Error: 'C:/Users/c1026xx/AppData/Local/Temp/3D33799616818940950.anstranslator\._1' is not a valid ODB++ directory
      Total Errors: 1 Total Warnings: 0
      Translation Stop: Wed Apr 19 09:48:16 2023
      How can I solve thids issue?
      Best Regards,
      Glenn
    • kchan
      I'm having the similar problem.  Did you find a solution yet?
    • Michael Mohle
      I'm having the same problem in AED but can import into SI Wave.
    • Glenn Galea
      Hi All,
      I belive, I just messed around with the export settings for a while and then it kind of fixed itself. I can't quite remeber exactly what I did.
    • Michael Mohle
      Where did you access the export settings?
    • Glenn Galea
      The export settings of Mentor Graphics to generate the odb++ file. I had to mess about with which components of the pcb to export. I rember playing around with the tick boxes and the file paths till I managed to get it to export
    • Mrinmoy Bharadwaj
      This seems to be an error from the odb extraction process in the Mentor tool. Kindly follow the guidelines prescribed in the mentor tool for a correct odb extraction. Alternatively, you may use IPC2581 format as well.
Viewing 6 reply threads
  • The topic ‘Unable to Import Mentor Xpedetion ODB++ File into SIWave’ is closed to new replies.
