Unable to extract Force Reactions results.
    • theroesii
      When using Ansys 24R1 version of Workbench for Random Vibration simulation, I came across an error message stating "The data required to calculate the spectrum reactions is missing. Please send the database to your Ansys support distributor." This error occurs when I try to extract the Force Reaction (Random Vibration - Solution - Insert - Probe - Force Reaction).
      I have already double-checked and confirmed that I have enabled the Calculate Reactions switch in the Modal module.
      If anyone has any insights on how to resolve this issue, I would greatly appreciate your assistance. Thank you!
    • mjmiddle
      Please turn on the nodal forces in the output section of the analysis settings in the modal analysis:
      • theroesii
        Almost all the options are turned on, but none of them are useful.
    • mjmiddle
      To what is the force reaction scoped?
  • The topic ‘Unable to extract Force Reactions results.’ is closed to new replies.
