3D Design
3D Design
Unable to establish connections in ansys fluent
    • Devanshi109
      I have 5x4 arrangement cylindrical cells, with air domain modeled, but ansys is not applying manual connection to the cylinder walls and the domain.
      When I try to apply manual connection, I can't change the type from Bonded type.
      Any help would be appreciated thanks!
      If you're using Fluent why do you want bonded contacts?
    • Devanshi109
      That's exactly the problem, when i make manual contacts, fluent is making it bonded by default and im unable to change that.
      If you create a multibody part there should be no contacts. If you transfer contact to Fluent it'll create an interface: this deals with most of the flow and thermal effects.
  • The topic ‘Unable to establish connections in ansys fluent’ is closed to new replies.
