February 4, 2020 at 4:25 pm
fischr
SubscriberHello,
i want to import a temperature load to a static structural simulation in Workbench R19. But the solver engine is unable to converge on a solution. I used a command block to insert HSFLD242 Elements to model a fluid that is fully enclosed by solids.
The cavity is filled with HSFLD242 elements as you can see in the picture below:
does anyone have any idea why it is not converging? Do i need to define a thermal conductance for the material properties of my fluid ?
February 5, 2020 at 3:12 am
peteroznewman
SubscriberThere is useful information in the solve.out file in the solution folder. What is the error listed in that file? It looks like it nearly solved completely. Without seeing the information, it might help to have smaller elements.
February 5, 2020 at 10:59 am
fischr
SubscriberThanks for your reply. I tried a finer mesh, but it is still not converging and not even showing the heat convergence data.
The error messages are:
/COM,ANSYS RELEASE Release 19.0Â Â Â Â Â BUILD 19.0Â Â Â Â Â UP20171214Â Â Â Â Â Â 11:54:10
 *** WARNING ***                        CP =      1.391  TIME= 11:54:12
 Material property ALPX of material 1 is evaluated at a temperature of Â
 0, which is below the supplied temperature range. Temperature range  Â
 checking terminates.                                                  Â
 *** WARNING ***                        CP =      1.625  TIME= 11:54:12
 Element shape checking is currently inactive. Issue SHPP,ON or       Â
 SHPP,WARN to reactivate, if desired.                                  Â
 *** WARNING ***                        CP =      5.391  TIME= 11:54:15
 Pivoting has been activated for the Distributed Sparse Matrix Solver .Â
 The memory required may greatly exceed the predicted amount. In that Â
 event, use the DSPOPTION command to change the memory mode and/or     Â
 memory size used by the Distributed Sparse Matrix Solver.             Â
 *** WARNING ***                        CP =     16.516  TIME= 11:54:26
 There is not enough memory for the Distributed Sparse Matrix Solver toÂ
 proceed in the in-core memory mode. The Distributed Sparse Matrix    Â
 Solver will now restart using the out-of-core memory mode.            Â
 *** WARNING ***                        CP =     16.797  TIME= 11:54:27
 The Distributed Sparse Matrix Solver is currently running in the      Â
 out-of-core memory mode. This memory mode may provide significantly  Â
 worse performance compared to the in-core memory mode, depending on   Â
 the amount of available system memory and I/O speed. Please monitor  Â
 the solver performance to ensure that the large amount of I/O to the  Â
 solver files does not create a bottleneck for performance.            Â
 *** ERROR ***                          CP =     36.172  TIME= 11:54:46
 proceed. This is likely due to the use of pivoting while factoring   Â
 the matrix. Please increase the virtual memory on your system and/or Â
 increase the work space memory and rerun the solver. Alternatively,  Â
 using the DSPOPTION command to switch to a different memory mode      Â
 and/or to specify additional memory for the solver may also help. TheÂ
 memory currently allocated for the Distributed Sparse Matrix Solver   Â
 solver = 134 MB.  Â
February 5, 2020 at 11:08 am
fischr
Subscriberwith a course mesh i get these error messages:
/COM,ANSYS RELEASE Release 19.0 BUILD 19.0 UP20171214 12:03:18
*** WARNING *** CP = 0.297 TIME= 12:03:19
*** WARNING *** CP = 0.359 TIME= 12:03:19
*** WARNING *** CP = 0.500 TIME= 12:03:19
*** WARNING *** CP = 0.984 TIME= 12:03:19
Material property KXX of material 1 of element 172 is evaluated at a
temperature of 546.910916, which is above the supplied temperature
range. Temperature range checking terminates.
*** WARNING *** CP = 2.266 TIME= 12:03:20
*** WARNING *** CP = 3.797 TIME= 12:03:22
*** WARNING *** CP = 5.266 TIME= 12:03:23
*** WARNING *** CP = 11.250 TIME= 12:03
0
Solution not converged at time 0.1 (load step 1 substep 1).
Run continued at user request.
*** WARNING *** CP = 17.609 TIME= 12:03
6
Solution not converged at time 0.2 (load step 1 substep 2).
*** WARNING *** CP = 23.797 TIME= 12:03:43
Solution not converged at time 0.3 (load step 1 substep 3).
*** WARNING *** CP = 30.141 TIME= 12:03:49
Solution not converged at time 0.4 (load step 1 substep 4).
*** WARNING *** CP = 36.250 TIME= 12:03:56
Solution not converged at time 0.5 (load step 1 substep 5).
*** WARNING *** CP = 42.516 TIME= 12:04:02
Solution not converged at time 0.6 (load step 1 substep 6).
*** WARNING *** CP = 48.547 TIME= 12:04:08
Solution not converged at time 0.7 (load step 1 substep 7).
*** WARNING *** CP = 54.844 TIME= 12:04:15
Solution not converged at time 0.8 (load step 1 substep
*** WARNING *** CP = 61.031 TIME= 12:04:21
Solution not converged at time 0.9 (load step 1 substep 9).
*** WARNING *** CP = 67.109 TIME= 12:04:28
Solution not converged at time 1 (load step 1 substep 10).
Without using HSFLD242 elements the solution is converging.
February 5, 2020 at 11:14 am
fischr
Subscriberand if i set solver pivot checking on programm controlled i get these error messages:
/COM,ANSYS RELEASE Release 19.0Â Â Â Â Â BUILD 19.0Â Â Â Â Â UP20171214Â Â Â Â Â Â 12:09:40
 *** WARNING ***                        CP =      0.297  TIME= 12:09:41
 *** WARNING ***                        CP =      0.359  TIME= 12:09:41
 *** WARNING ***                        CP =      0.516  TIME= 12:09:41
 *** ERROR ***                          CP =      0.969  TIME= 12:09:41
 There are 543 small equation solver pivot terms (e.g., at the UY degree
 of freedom of node 494). Please check for an insufficiently          Â
 constrained model. -
February 5, 2020 at 11:45 am
February 6, 2020 at 1:49 pm
peteroznewman
SubscriberI read the ANSYS help on the assumptions and restrictions on the HSFLD242 element and find that the fluid volume must have a uniform temperature without any gradients. That doesn't seem to be consistent with a Transient Thermal model where temperature gradients are present.
Try to use a CPT217 element which is capable of modeling coupled physics phenomena such as structural-pore-fluid-diffusion-thermal analysis and structural implicit gradient regularization using a nonlocal field. The element has a quadratic displacement, and linear pore-pressure and temperature behavior. With KEYOPT(11)=1, you specify you want a Structural-Thermal coupled field analysis.
Because it is a coupled-field analysis, you provide both thermal BCs and structural BCs and issue an ANTYPE,SOIL command and use the spares direct solver.Â
February 6, 2020 at 2:23 pm
fischr
SubscriberOkay thank you for your answer! I will try using CPT217 Elements for the Fluid. I suppose I have to model the body of the fluid and mesh the fluidbody with CPT217? Then I have to model the contact between solid and fluid as well, is that right?
February 6, 2020 at 4:26 pm
peteroznewman
SubscriberIf I had used DesignModeler or SpaceClaim to prepare this geometry, I would have used Shared Topology so that nodes on the spherical surface were shared by the fluid elements on one body and the solid elements on the other body. In that case, I don't need any contact.
February 6, 2020 at 4:49 pm
fischr
SubscriberCould you please explain how to implement CPT217 elements in ansys workbench?
I inserted a command snippet under the individual part (fluid) in Geometry tree:
ET,matid, CPT217
keyopt,matid,11,1
But this did not change the element type from SOLID187 to CPT217
February 6, 2020 at 6:46 pm
peteroznewman
SubscriberCheck the Solution Output to verify that SOLID187 elements were used in the mesh. Perhaps the mesh used linear elements? You can set the mesh to use quadratic elements.
February 7, 2020 at 2:02 pm
fischr
Subscriber -
February 11, 2020 at 4:49 pm
fischr
Subscriberit is still not working.
- i used shared topology
- inserted a command snippet under the body of the fluid with:
et,2,217
keyopt,2,11,1
keyopt,2,12,1
- set the solver type to: direct
- made a command snippet in solu:
antype,soil
- used Full-Newton-Raphson-method, because i had error message:
The THOPT,QUASI option is valid only for the TEMP degree of freedom
it is still not finishing the solution :
in the error file i have only warning:
/COM,ANSYS RELEASE Release 19.0 BUILD 19.0 UP20171214 17
0:18
*** WARNING *** CP = 0.297 TIME= 17
0:19
Material property ALPX of material 2 is evaluated at a temperature of
*** WARNING *** CP = 0.328 TIME= 17
0:19
*** WARNING *** CP = 0.953 TIME= 17
0:19
Material property EX of material 2 of element 812 is evaluated at a
temperature of 473.991869, which is above the supplied temperature
*** WARNING *** CP = 1.109 TIME= 17
0:19
A reference fluid flow value times the tolerance is used by the
Newton-Raphson method for checking convergence. The calculated
reference FL FLOW CONVERGENCE VALUE= 0 is less than a threshold. This
threshold defaults to 1.0e-6 or is specified as MINREF on the CNVTOL
command. Check results carefully.
any suggestions on what to do?
February 11, 2020 at 10:37 pm
peteroznewman
SubscriberYou are getting 200 converged increments. Why do you say it is not working?
What do the results look like during these converged increments?
You are only showing warnings, not errors.
February 12, 2020 at 11:11 am
fischr
Subscriberi can't plot any results, i have a read lightning bolt symbol :
this are the last steps from the solver output:
    FORCE CONVERGENCE VALUE = 0.2116E-05 CRITERION= 0.5312E-04
    FL
FLOW CONVERGENCE VALUE=Â Â 0.000Â Â Â Â Â CRITERION=Â 0.5312E-08
    HT FLOW
CONVERGENCE VALUE=Â 0.5705E-11Â CRITERION=Â 0.1000E-05
    DISP CONVERGENCE
VALUEÂ Â =Â 0.6118E-09Â CRITERION=Â 0.2784E-05 <<< CONVERGED
EQUIL ITER  1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.2388E-05
FORCE CONVERGENCE VALUEÂ =Â 0.1900E-11Â CRITERION=Â 0.1062E-03 <<<
CONVERGED
    FL FLOW CONVERGENCE VALUE= 0.4197E-24 CRITERION= 0.5312E-08
<<< CONVERGED
    HT FLOW CONVERGENCE VALUE= 0.7400E-13Â
CRITERION=Â 0.1000E-05 <<< CONVERGED
   >>> SOLUTION
CONVERGED AFTER EQUILIBRIUM ITERATIONÂ Â 1
 *** LOAD STEP    1  SUBSTEP Â
193 COMPLETED.   CUM ITER =   195
 *** TIME = 0.970000        TIME INC
=Â 0.500000E-02
 *** RESPONSE EIGENVALUE = 6.590      OSCILLATION LIMIT =
0.3295E-01
 *** RESPONSE FREQ = 0.3964E+05  PERIOD= 0.2522E-04 PTS/CYC =
0.50E-02
 *** AUTO STEP TIME: NEXT TIME INC = 0.50000E-02Â
UNCHANGED
    FORCE CONVERGENCE VALUE = 0.2105E-05 CRITERION=Â
0.5312E-04
    FL FLOW CONVERGENCE VALUE=  0.000     CRITERION=Â
0.5312E-08
    HT FLOW CONVERGENCE VALUE= 0.5705E-11 CRITERION=Â
0.1000E-05
    DISP CONVERGENCE VALUE  = 0.5800E-09 CRITERION=Â
MATRIX. MAX DOF INC= 0.2375E-05
    FORCE CONVERGENCE VALUE =Â
0.1842E-11Â CRITERION=Â 0.1062E-03 <<< CONVERGED
    FL FLOW
CONVERGENCE VALUE=Â 0.4489E-24Â CRITERION=Â 0.5312E-08 <<<
CONVERGED
    HT FLOW CONVERGENCE VALUE= 0.7400E-13 CRITERION= 0.1000E-05
<<< CONVERGED
   >>> SOLUTION CONVERGED AFTER EQUILIBRIUM
ITERATIONÂ Â 1
 *** LOAD STEP    1  SUBSTEP  194 COMPLETED.   CUM ITER
=Â Â Â 196
 *** TIME = 0.975000        TIME INC = 0.500000E-02
RESPONSE EIGENVALUE =Â 6.590Â Â Â Â Â Â OSCILLATION LIMIT = 0.3295E-01
RESPONSE FREQ = 0.3963E+05Â Â PERIOD=Â 0.2524E-04Â PTS/CYC = 0.50E-02
AUTO STEP TIME:Â NEXT TIME INC = 0.50000E-02Â UNCHANGED
    FORCE
CONVERGENCE VALUEÂ =Â 0.2095E-05Â CRITERION=Â 0.5312E-04
    FL FLOW
    HT FLOW
    DISP CONVERGENCE
VALUEÂ Â =Â 0.6052E-09Â CRITERION=Â 0.2784E-05 <<< CONVERGED
EQUIL ITER  1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.2362E-05
FORCE CONVERGENCE VALUEÂ =Â 0.1878E-11Â CRITERION=Â 0.1062E-03 <<<
CONVERGED
    FL FLOW CONVERGENCE VALUE= 0.4287E-24 CRITERION= 0.5312E-08
<<< CONVERGED
   >>> SOLUTION
195 COMPLETED.   CUM ITER =   197
 *** TIME = 0.980000        TIME INC
=Â 0.500000E-02
0.3295E-01
 *** RESPONSE FREQ = 0.3961E+05  PERIOD= 0.2525E-04 PTS/CYC =
0.50E-02
UNCHANGED
    FORCE CONVERGENCE VALUE = 0.2085E-05 CRITERION=Â
0.5312E-04
0.5312E-08
0.1000E-05
    DISP CONVERGENCE VALUE  = 0.5737E-09 CRITERION=Â
MATRIX. MAX DOF INC= 0.2349E-05
0.1918E-11Â CRITERION=Â 0.1062E-03 <<< CONVERGED
    FL FLOW
CONVERGENCE VALUE=Â 0.4431E-24Â CRITERION=Â 0.5312E-08 <<<
CONVERGED
<<< CONVERGED
ITERATIONÂ Â 1
 *** LOAD STEP    1  SUBSTEP  196 COMPLETED.   CUM ITER
=Â Â Â 198
 *** TIME = 0.985000        TIME INC = 0.500000E-02
RESPONSE FREQ = 0.3959E+05Â Â PERIOD=Â 0.2526E-04Â PTS/CYC = 0.51E-02
    FORCE
CONVERGENCE VALUEÂ =Â 0.2075E-05Â CRITERION=Â 0.5312E-04
    FL FLOW
    HT FLOW
    DISP CONVERGENCE
VALUEÂ Â =Â 0.5984E-09Â CRITERION=Â 0.2784E-05 <<< CONVERGED
EQUIL ITER  1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.2336E-05
FORCE CONVERGENCE VALUEÂ =Â 0.1928E-11Â CRITERION=Â 0.1062E-03 <<<
CONVERGED
    FL FLOW CONVERGENCE VALUE= 0.4688E-24 CRITERION= 0.5312E-08
<<< CONVERGED
   >>> SOLUTION
197 COMPLETED.   CUM ITER =   199
 *** TIME = 0.990000        TIME INC
=Â 0.500000E-02
0.3295E-01
 *** RESPONSE FREQ = 0.3957E+05  PERIOD= 0.2527E-04 PTS/CYC =
0.51E-02
UNCHANGED
    FORCE CONVERGENCE VALUE = 0.2065E-05 CRITERION=Â
0.5312E-04
0.5312E-08
0.1000E-05
    DISP CONVERGENCE VALUE  = 0.5676E-09 CRITERION=Â
MATRIX. MAX DOF INC= 0.2323E-05
0.1916E-11Â CRITERION=Â 0.1062E-03 <<< CONVERGED
    FL FLOW
CONVERGENCE VALUE=Â 0.5016E-24Â CRITERION=Â 0.5312E-08 <<<
CONVERGED
<<< CONVERGED
ITERATIONÂ Â 1
 *** LOAD STEP    1  SUBSTEP  198 COMPLETED.   CUM ITER
=Â Â Â 200
 *** TIME = 0.995000        TIME INC = 0.500000E-02
RESPONSE FREQ = 0.3955E+05Â Â PERIOD=Â 0.2529E-04Â PTS/CYC = 0.51E-02
    FORCE
CONVERGENCE VALUEÂ =Â 0.2054E-05Â CRITERION=Â 0.5312E-04
    FL FLOW
    HT FLOW
    DISP CONVERGENCE
VALUEÂ Â =Â 0.5913E-09Â CRITERION=Â 0.2784E-05 <<< CONVERGED
EQUIL ITER  1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.2310E-05
FORCE CONVERGENCE VALUEÂ =Â 0.1778E-11Â CRITERION=Â 0.1062E-03 <<<
CONVERGED
    FL FLOW CONVERGENCE VALUE= 0.4592E-24 CRITERION= 0.5312E-08
<<< CONVERGED
   >>> SOLUTION
199 COMPLETED.   CUM ITER =   201
 *** TIME =  1.00000        TIME INC
=Â 0.500000E-02
0.3295E-01
 *** RESPONSE FREQ = 0.3953E+05  PERIOD= 0.2530E-04 PTS/CYC =
0.51E-02
also my global min of temperature is really low -2922°C , i set the ambient temperature to 200°C. i will try using a finer mesh.
February 12, 2020 at 4:36 pm
peteroznewman
SubscriberDelete the two result plots and insert a new Temperature result, then Evaluate All Results. Even though it is a red lightening bolt, there are still 200 converged substeps. In the tabular data, you can pick any one of those 200 rows and Retrieve Results. Now the display is showing a converged result. What does that look like?
February 12, 2020 at 4:43 pm
fischr
Subscriberand how can i describe the elasticity of my fluid in the material data? Is there a special setting for fluids? The elasticity of a fluid is described by the bulk modulus, but if i set the shear modulus to 0, my young modulus will also be 0 . Then it shows me a question mark in the definition of isotropic elasticity and i cannot perform a structural analysis.
February 12, 2020 at 6:59 pm
February 13, 2020 at 2:02 pm
fischr
Subscriberif i delete the result plots and insert a new temperature result, it is still not showing any tabular data. Under messages i get the error:
An error occurred when the post processor attempted to load a specific result. Please review all messages.
Current result file may not contain requested result data . Please clear the solution and solve again.
under solution information there is also no data to display for the temperature change.
February 13, 2020 at 3:24 pm
peteroznewman
SubscriberYou might have to open the model in Mechanical APDL to look at the results from a SOIL analysis type, I don't know. You might want to open a new Discussion to ask the specific question about obtaining results from a SOIL analysis. Someone else will have to answer that question.Â
You can try to open Mechanical APDL and open the results file in that application. I don't use that application so I can't help you with that either. I recommend performing a simple model in APDL that solves without error to get used to the user interface before you attempt to look at this SOIL model.
- The topic ‘Unable to converge on a solution’ is closed to new replies.
5654
1885
1404
1303
