July 17, 2017 at 2:07 pm
Zohreh
SubscriberHello every body!
I'm working on Box girder model. I wanna apply force until it will be broken. The box Girder has 2 arms. forces are applied on arms. But the solution can't converge. I checked everything like materials, mesh size , changed sub steps, load steps and NSF(Normal stiffness factor) and etc but they didn't work. how can i solve it? could you help me? -
July 18, 2017 at 9:48 pm
pgl
Ansys EmployeeSounds like a large deflection buckling simulation? If you are using Workbench then take a look at the product documentation Static Structural Analysis section starting on page 316. In that section review the following:
- Establish Analysis Settings (page 318) - See the note about Large DeflectionÂ
Also see these important sections
- Large Deflection (Page 843)
- Nonlinear Controls (page 860)
If you are old school and using ANSYS M-APDL then lookup the command NLGEOM,ON
Here's some scholarly articles on box girder simulations using ANSYS found on the web:Â
July 19, 2017 at 2:04 pm
Zohreh
SubscriberHello Dear pgl!
Thank you for helping. Yes, It's a large deflection buckling simulation. I'm using workbench. I don't know where is product documentation. How can I find it?
Thank u...
July 20, 2017 at 12:02 am
pgl
Ansys EmployeeOn Windows 10, go to your Windows/Start menu, select "All apps" then "ANSYS 18.0" scroll down the list of ANSYS applications and select  "ANSYS Help 18.0"
August 9, 2017 at 4:38 am
ding
Subscriber You can also change the criteria of convergence. If your model is concrete, please try to select displacement criteria of convergence. You can achieve it by using "CNVTOL,u,1,0.001,2"
- The topic ‘Unable to converge’ is closed to new replies.
5824
