December 7, 2021 at 4:55 pm
Siyi
SubscriberWhen I try to activate the evaluation code (trial license), I input the activation code by using the online mode, but it shows a pop-up window that the activation failed "Unable to connect to the activation server. Please check your connection settings."
Does anyone know how to fix it?
December 7, 2021 at 7:17 pmLito
Ansys EmployeeTrial license requires an Internet connection. Ensure that you are connected to the Internet and if you are using a proxy server check your settings. Otherwise, connect to the Internet directly not through your organization's network.
December 7, 2021 at 9:41 pmSiyi
SubscriberHi thanks for your reply, but the problem still exists.
Since I am using a desktop at my university. I plugged out the internet cable then I tried to connect via wireless by using my cellphone's hotspot. But the problem is still there, showing unable to connect to the server. But there is no problem with my internet connection. Is it possible that there is a problem with the code?
Thanks Siyi
December 7, 2021 at 9:49 pmLito
Ansys EmployeeBased on your account, you have the trial license for the following products/solvers: MODE, Multiphysics, INTERCONNECT, and FDTD. We tested the activation code and there are no issues. Try to activate the license on a different machine, i.e your personal laptop. Your university desktop might not allow connecting or communicating with our license activation servers.
December 8, 2021 at 1:58 amSiyi
SubscriberThanks. Do you know if Lumerical supports OS system, since my personal laptop is Macbook Air? But I could not find the download version for OS.
December 8, 2021 at 6:41 pmLito
Ansys EmployeeYou can download the MacOS version from the Lumerical Downloads page. The Node-locked trial license will work on MacOS.
December 12, 2021 at 7:36 pmSiyi
SubscriberThanks. It works on my personal MacOS.
Viewing 6 reply threads- The topic ‘Unable to connect the server during activation’ is closed to new replies.
5794
