Unable to connect solution to result.
    • S K
      I would like to transfer solution data from A and B to results in C, but I am unable to do that. What should I do? I am using Ansys student (2024 R2). Thank you
    • ErKo
      Hi
      A clue is in the symbol of this system (fluid flow symbol) which is the same as the CFD related products.
      It is a results system (system is CFD-Post) to view CFD related results say from Fluent (so not from the Thermal Structural as it is not a CFD product).
      Closing this as others might find it useful.
      Thank you
      Erik
  • The topic ‘Unable to connect solution to result.’ is closed to new replies.
