September 9, 2024 at 2:21 pm
aashah28
SubscriberI am using Lumerical 2024 R1.3 and have set up a simple model and am attempting to send a plane wave towards it, starting from some zheight above the model. However, every time I try to change the geometry by clicking Edit Source --> Geometry --> Apply, the settings automatically default back to zero and will not save my new inputs. I tried changing the plane wave geometry using a script, but that also did not work. Does anybody have suggestions for how to change the geometry and get around what seems to be a new bug in this version?
September 9, 2024 at 3:54 pm
acb20
SubscriberSame problem here with Lumerical 2024 R2.1. You can move it by clicking on the object and dragging it, but I don't know a way to do it precisely
September 9, 2024 at 4:02 pm
acb20
SubscriberOK, one workaround is that you can make a new group that contains just the planewave, and then do relative movements to the group to get precise changes. Hopefully the default size is big enough, I don't know a way to change that.
September 9, 2024 at 4:06 pm
aashah28
SubscriberI found another workaround. You install a Gaussian source, and then edit the geometry in the Gaussian source. When you're ready to move to a simulation, change the source shape to a plane wave and the geometry will persist.Â
September 9, 2024 at 4:26 pm
acb20
SubscriberOh that's much nicer, thank you
September 10, 2024 at 6:41 pm
Guilin Sun
Ansys EmployeeThis happens for the specific version. Please download and install the newest version and it should work as expected.Â
