July 25, 2023 at 2:29 pm
Manu
SubscriberI made a 2d basic design in Discovery for a Steady State Thermal analysis but I get this problem when I open the model:
The analysis type is setted to 2D.
I also couldn't import the geometry.
Ansys Version:Â
2023 R1ÂPoint Releases and Patches installed:ÂDiscovery 2023 R1Autodyn 2023 R1SpaceClaim 2023 R1CFX (includes CFD-Post) 2023 R1Chemkin 2023 R1EnSight 2023 R1FENSAP-ICE 2023 R1Fluent (includes CFD-Post) 2023 R1Polyflow (includes CFD-Post) 2023 R1Forte (includes EnSight) 2023 R1TurboGrid 2023 R1Aqwa 2023 R1Speos 2023 R1Mechanical Products 2023 R1Material Calibration App 2023 R1ACIS Geometry Interface 2023 R1AutoCAD Geometry Interface 2023 R1Catia, Version 4 Geometry Interface 2023 R1Catia, Version 5 Geometry Interface 2023 R1Catia, Version 6 Geometry Interface 2023 R1Creo Elements/Direct Modeling Geometry Interface 2023 R1Creo Parametric Geometry Interface 2023 R1Inventor Geometry Interface 2023 R1JTOpen Geometry Interface 2023 R1NX Geometry Interface 2023 R1Parasolid Geometry Interface 2023 R1Solid Edge Geometry Interface 2023 R1SOLIDWORKS Geometry Interface 2023 R1Academic Student 2023 R1I would appreciate any guidance to solve this issue.
July 26, 2023 at 7:33 pm
Gary_S
Ansys Employee.AGDB file extension is for the older DesignModeler product.Â
In general, you would not use DesignModeler, but rather transfer from Discovery directly into a Steady State thermal, or structural etc.Â
August 11, 2023 at 12:48 pm
August 11, 2023 at 1:03 pm
Gary_S
Ansys EmployeeÂ
Hi Manu
The error does not give any useful information.
Are you able to open file NewDesign.4.dsco via File > Open in Discovery?Â
Gary
August 11, 2023 at 2:24 pm
Manu
SubscriberI have been able to correct the error using this method in Discovery:
I don't understand it completely but seems to be that enabling this 3D mode button the original 2d sketch (a rectangle in this case) is turned into a surface that the Mechanical Ansys could analize it.
If you have any further explanation, it would be welcome.Thanks
August 11, 2023 at 2:29 pm
Gary_S
Ansys EmployeeA sketch by itself is not a entity that can be attached or analyzed.
A sketch can be converted to Line Bodies, or if a closed form sketch, a 2D surface.
These entities can be attached into Ansys Mechanical.
August 11, 2023 at 2:37 pm
Manu
SubscriberThanks for the explanation!
- The topic ‘Unable to attach to geometry file error’ is closed to new replies.
5824
