February 12, 2019 at 10:56 am
ak22
SubscriberIn ansys 19.2 after drawing geometry (surface), when i close ansys dosen't tick mark green against geometry. If I import it, it does tick mark green but after opening model there is error unable to attach geometry.
I tried solutions of similar threads but none of it worked. Please help
System.Exception: Unable to attach to geometry file C:UsersangarDocumentsansys2dbar.scdoc. Unable to attach geometry.
  at Ansys.Simulation.Core.Commands.RefreshModel.ExecuteCommand(IFullContext context)
  at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute(IFullContext context)
  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: Unable to attach to geometry file C:UsersangarDocumentsansys2dbar.scdoc. Unable to attach geometry.
CommandName: Mechanical.RefreshModel(Container="Model", RemainingContainers=[])
  at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
  at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
  at Ansys.ProjectSchematic.Commands.RefreshCommand.RefreshComponents(IFullContext context, IEnumerable`1 componentsToRefresh, Boolean refreshUnfulfilled)
CommandName: RefreshComponent(Component="/Schematic/Component:Model")
  at Ansys.ProjectSchematic.Commands.RefreshComponentCommand.InvokeAndWait(IProtectedContext context, DataReference Component)
  at Ansys.Simulation.GUI.EditModelBase.InvokeEditModelOperation(GuiOperationContext context, IGuiOperation guiOperation, DataContainerReference dcr)
  at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
  at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction, Boolean deferredRefreshOnly) -
February 12, 2019 at 1:49 pm
Keyur Kanade
Ansys Employeecan you please insert images. it is not clear to me if you are closing spaceclaim or ansys.
February 12, 2019 at 3:18 pm
ak22
Subscriberafter closing spaceclaim only
February 12, 2019 at 7:15 pm
Fernando Torres
SubscriberHi , change analysis from '3d' to '2d' and check if it makes any difference. Thanks.
February 13, 2019 at 5:00 am
ak22
Subscriberits solved by changing extension from sdoc to igs
thanks
February 13, 2019 at 5:27 am
Keyur Kanade
Ansys Employeegood.Â
please mark this as 'is solution' to help others on forum.Â
- The topic ‘‘unable to attach Geometry’ and ‘The geometry editor colsed abnormally’’ is closed to new replies.
3637
1313
1142
1069
1013
