Ansys Products
Ansys Products
Unable to access ACT Application Store to download .wbex file for Topology Optimization extention
    • ChrisN
      Knowledge Resources: Solutions #2053111 states: "To get ANSYS Topology Optimization ACT for v17.x you will need to download it from the Customer Portal.
      Downloads > ANSYS ACT Application Store 17.
      You'll then be in the ACT store. You should see several Ansys Topology Optimization v1. Download and install the version that matches your release of ANSYS."
      However, there is no "ANSYS ACT Application Store 17" option under Downloads.
      How can I get the Topography Optimization extension installed for ANSYS Workbench 17.1?
    • tsiriaks
      The ANSYS app store is now moved to
      https://catalog.ansys.com/
      You can search for 'topology' in there and you should be able to find it.
      Make sure you use the correct version. There are 17.0, 17.1, and 17.2 in there.
      Thanks,
      Win
    • ChrisN
      Great, thank you!
  • The topic ‘Unable to access ACT Application Store to download .wbex file for Topology Optimization extention’ is closed to new replies.
