LS Dyna
LS Dyna
UMAT 2025 R2. DAMAGE IS NOT UPDATING
    • pavan_m240846ce
      After compiling the umat code and using it, the mesh deformation is not visible in the post processing. this is the code which I replaced in the subroutine umat 41. It is just not showing the deformation but there is change in the resultant velocity at nodes. What may the reason and how to fix this.
       subroutine umat41 (cm,eps,sig,epsp,hsv,dt1,capa,etype,tt,
           & temper,failel,cma,qmat,elsiz,idele,reject)
            include 'nlqparm'
            include 'bk06.inc'
            include 'iounits.inc'
            dimension cm(*),eps(*),sig(*),hsv(*),cma(*),qmat(3,3)
            logical failel,reject
            character*5 etype
            integer*8 idele
      c ===============================
      c LOCAL VARIABLES
            real*8 Kmod,Gmod,sig_t,phi,coh,alpha,beta
            real*8 Kmod_d,Gmod_d
            real*8 eps_v,eps_cr,Cd,D
            real*8 e1,e2,e3
            real*8 I1,J2,s1,s2,s3
            real*8 phi_r,dp_a,dp_k,f,scale
            real*8 tiny
            tiny = 1.0d-20
      c MATERIAL PARAMETERS FROM CARD
            Kmod  = cm(1)
            Gmod  = cm(2)
            sig_t = cm(3)
            phi   = cm(4)
            coh   = cm(5)
            alpha = cm(6)
            beta  = cm(7)
      c ONLY FOR SOLID TYPE ELEMENTS
            if (etype.eq.'solid'.or.etype.eq.'sph  '.or.
           &    etype.eq.'sldax'.or.etype.eq.'sld2d') then
            if (.not.failel) then
      c VOLUMETRIC STRAIN
            eps_v = eps(1)+eps(2)+eps(3)
      c CRITICAL TENSILE STRAIN
      c (using bulk modulus relation)
            eps_cr = sig_t/(3.d0*Kmod + tiny)
      c DAMAGE EVOLUTION
            if (eps_v.gt.eps_cr) then
               Cd = alpha*(eps_v-eps_cr)**beta
            else
               Cd = 0.d0
            endif
            D = 1.d0 - dexp(-Cd)
      c DEGRADED STIFFNESS
            Kmod_d = (1.d0-D)*Kmod
            Gmod_d = (1.d0-D)*Gmod
      c DEVIATORIC STRAIN
            e1 = eps(1)-eps_v/3.d0
            e2 = eps(2)-eps_v/3.d0
            e3 = eps(3)-eps_v/3.d0
      c ELASTIC STRESS UPDATE
            sig(1)=sig(1)+Kmod_d*eps_v+2.d0*Gmod_d*e1
            sig(2)=sig(2)+Kmod_d*eps_v+2.d0*Gmod_d*e2
            sig(3)=sig(3)+Kmod_d*eps_v+2.d0*Gmod_d*e3
            sig(4)=sig(4)+Gmod_d*eps(4)
            sig(5)=sig(5)+Gmod_d*eps(5)
            sig(6)=sig(6)+Gmod_d*eps(6)
      c DRUCKER-PRAGER YIELD CHECK
            I1 = sig(1)+sig(2)+sig(3)
            s1 = sig(1)-I1/3.d0
            s2 = sig(2)-I1/3.d0
            s3 = sig(3)-I1/3.d0
            J2 = 0.5d0*(s1*s1+s2*s2+s3*s3)
           &     +sig(4)*sig(4)+sig(5)*sig(5)+sig(6)*sig(6)
            phi_r = phi*3.14159265358979d0/180.d0
            dp_a = 2.d0*dsin(phi_r)/(dsqrt(3.d0)*(3.d0-dsin(phi_r)))
            dp_k = 6.d0*coh*dcos(phi_r)/(dsqrt(3.d0)*(3.d0-dsin(phi_r)))
            f = dsqrt(J2 + tiny)-3.d0*dp_a*I1-dp_k
      c RADIAL RETURN (STABLE)
            if (f.gt.0.d0) then
               scale = (3.d0*dp_a*I1+dp_k)/(dsqrt(J2)+tiny)
               sig(1)=sig(1)*scale
               sig(2)=sig(2)*scale
               sig(3)=sig(3)*scale
               sig(4)=sig(4)*scale
               sig(5)=sig(5)*scale
               sig(6)=sig(6)*scale
            endif
            endif
            endif
            return
            end.
    • ErKo
      Hi
      Debugging of UMAT is outside the scope of the help Ansys employees can provide here.
      Please wait though for other forum members (D Chen), that have experience with UMATS to chime in perhaps and provide feedback.
      Thank you for your understanding, and all the best
      Erko
