UDL ON A BEAM
    • pankaj
      Hi
      how to perform uniform distributed load test in ANSYS mechanical.
      i have tried using pressure but when i was selected the face it performing point loading.
    • sathya
      Hi UDL is related to Beam.
      For 3D model, it has to be applied as Force on Face only.
      The graphics will be shown as pointed.
      You can confirm the same by reaction after solving.
    • pankaj
      I was expecting this answer
      see in this I have applied same load using face selection but it showing different result both side  Why
    • jj77
      Can you post/attach your model and then we can have a look why this happens
    • sathya
      Make sure the setup is symmetric at an imaginary plane along geometry normal.
      From the imaginary symmetric plane ,the mesh count should be same on both sides.
      Prefer uniform Hex only mesh.
    • Sam_98
      Hello everyone, nI am trying to apply a Uniformly Distributed Load on an edge, could anyone please let me know which is the right command to use?nBecause, when a Force or Line pressure is applied, the results are obtained as a point load.nIt would be really helpful if anyone could help me out.n
Viewing 5 reply threads
  • The topic ‘UDL ON A BEAM’ is closed to new replies.
