May 24, 2024 at 1:37 am
Zwernjayden
SubscriberMy udf works when I select the planar option, even with an axis BC, but when I select axisymmetric, the heat flux is 10x higher than expected. I only want the heat flux radial direction (y direction), which is maybe why.
#include "udf.h"#includeÂ#define rho 950 // kg/m^3#define Hg 2033631 // J/Kg#define Hf -310000 // J/Kg#define T_ref 298 // K#define A1 0.01104 // m/s#define A2 3.9648 // m/s#define Cp 1500 // J/(Kg*K)#define E1 20557.188 // J/mol#define E2 55893.78 // J/mol#define R_u 8.314 // J/(mol*K)#define alpha 0.3ÂDEFINE_PROFILE(surface_temperature_profile, t, position){  face_t f;  real Ts, heat_flux, heat, a_face, Hv, r, Ts_old, Ts_new, error, Ts_new_prime, Area[ND_ND];  int iter;  begin_f_loop(f, t)  {    Ts = F_T(f, t); // Current temperature at the face    printf("Temp of face %d: %g K\n", f, Ts);    heat = BOUNDARY_HEAT_FLUX(f, t); // Calculating the heat flux at face f in watts    F_AREA(Area, f, t);    a_face = NV_MAG(Area);    heat_flux = heat / a_face; // Heat flux in W/m^2    printf("Heat flux on face %d: %g W/m^2\n", f, heat_flux);    Ts_old = Ts;    iter = 0;    error = 1;    while (error > 1e-6 && iter < 100)    {      Hv = Hg - Hf + Cp * (Ts - T_ref); // Calculation heat of formation      r = (fabs(heat_flux)) / (Hv * rho); // Regression rate      if (Ts_old > 722)      {        Ts_new = E1 / (R_u * (log(A1) - log(r))); // New surface temperature for high temperature      }      else      {        Ts_new = E2 / (R_u * (log(A2) - log(r))); // New surface temperature for low temperature      }      error = fabs(Ts_new - Ts_old); // Error calculation      Ts_old = Ts_new; // Update Ts_old for next iteration      iter++; // Increment iteration count    }    Ts_new_prime = Ts + (alpha * (Ts_new - Ts));Âr = (fabs(heat_flux)) / (Hv * rho);    printf("New Temp %d: %g K\n", f, Ts_new_prime);    printf("r_dot %d: %g mm/s\n", f, r*1000);    F_PROFILE(f, t, position) = Ts_new_prime; // Update the face temperature profile  }  end_f_loop(f, t)} -
July 29, 2024 at 2:19 pm
SRP
Ansys EmployeeHi,
In axisymmetric simulations, Fluent automatically accounts for the circumferential integration when calculating fluxes and forces. In an axisymmetric case, the heat flux needs to be interpreted correctly. Fluent handles the circumferential scaling internally, so your calculations need to be adjusted accordingly. Specifically, the heat flux should be divided by 2*pi*r.
Thank you.
- The topic ‘UDF works in planar option but not axisymmetric’ is closed to new replies.
1306
