November 24, 2020 at 12:21 am
md_lidia
nWe are two undergraduate students seeking for help!!!nWe are trying to simulate a laminar flux through a 3D pipe (25 cm long, 2 cm of diameter) consisting of a multiphase flux (air and water). We want to implement a UDF for the velocity inlet consisting of several time-dependent square pulses. nIn our ideal scenario, the pipe is initially full of air and water is injected from the inlet periodically (every injection is a square pulse) and the amount of water decreases with each interval.  To do so, we have written the following code, but it does not seem to work:nCOULD ANYONE HELP PELASE?? HOW CAN WE SOLVE IT?nTHANK YOU VERY MUCH IN ADVANCE!nn
November 24, 2020 at 5:06 am
Keyur Kanade
Ansys EmployeeDuplicate of nWe are two undergraduate students seeking for help!!!We are trying to simulate a laminar flux through a 3D pipe (25 cm long, 2 cm of diameter) consisting of a multiphase flux (air and water). We want to implement a UDF for the velocity inlet consisting of several time-dependent square pulses. In our ideal scenario, the pipe is initially full of air and water is injected from the inlet periodically (every injection is a square pulse) and the amount of water decreases with each interval.  To do so, we have written the following code, but it does not seem to work:COULD ANYONE HELP PELASE?? HOW CAN WE SOLVE IT?THANK YOU VERY MUCH IN ADVANCE!https://us.v-cdn.net/6032193/uploads/M6KWPYIVT49E/screenshot-2020-11-24-at-01-05-22.pnghttps://us.v-cdn.net/6032193/uploads/0EL779KOZTUU/whatsapp-image-2020-11-24-at-00-50-20.jpeg/forum/discussion/22311/udf-velocity-inlet-profile-with-multiphase-mixture-ansys-fluent
n
- The topic ‘UDF VELOCITY INLET PROFILE WITH MULTIPHASE MIXTURE (ANSYS FLUENT)’ is closed to new replies.
5119
1831
1387
1248
