UDF using “gradient value” not working in parallel
    • Fuad87
      Hello All,
      I have written an UDF for my UDS. Now I need to use the gradient of that UDS to the momentum eqn as source. The problem is that the gradient of the UDS (C_UDSI_G(c,t,i)[j]) is not available when momentum equation is being solved unless I input "yes" to this “Keep temporary solver memory from being freed?”. But keeping memory is not available in parallel, hence I can use my code only in serial. How can I store the gradient of the UDS and use it as source to the momentum in parallel? TIA
    • DrAmine
      Which release are you using?
    • Fuad87
      I am using 17.2 academic
    • DrAmine
      With the documented way to obtain gradients (via Keep temporary solver memory from being freed? yes) I am able to obtain gradient for my UDS in parallel (R19.1).
    • Fuad87
      I couldn't do it in parallel. I don't know why. So tried this, but an error saying "Scalar_Reconstruction" is undefined variable.
      DEFINE_ADJUST(my_adjust,d)
      #if !RP_HOST
      int n;
      int phase_domain_index = 0;  /*primary phase index is 0 */
      Domain *domain;
              cell_t c;
              Thread *t;
      Thread *liq;
              domain = DOMAIN_SUB_DOMAIN(d,phase_domain_index);
      for (n=0; n
      MD_Alloc_Storage_Vars(domain, SV_UDSI_RG(n), SV_UDSI_G(n), SV_NULL);
      Scalar_Reconstruction(domain, SV_UDS_I(n), -1, SV_UDSI_RG(n), NULL);
      Scalar_Derivatives(domain, SV_UDS_I(n), -1, SV_UDSI_G(n), SV_UDSI_RG(n), NULL);
          thread_loop_c (t,d)
      liq = THREAD_SUB_THREAD(t,phase_domain_index);
      begin_c_loop (c,t)
      C_UDMI(c,t,0) = C_UDSI_G(c,liq,0)[0];
      C_UDMI(c,t,1) = C_UDSI_G(c,liq,1)[0];
      C_UDMI(c,t,2) = C_UDSI_G(c,liq,1)[1];
      C_UDMI(c,t,3) = C_UDSI_G(c,liq,2)[1];
      end_c_loop (c,t)
      #endif
    • DrAmine
      The documented approach is working for me in parallel. The approach you are posting is not documented and not supported. Anyway I managed to have gradients based on that approach. Alloc_Storage_Vars is the right function at first. Please help your self by writing debugging messages as they helped me actually to debug the errors.
Viewing 5 reply threads
  • The topic ‘UDF using “gradient value” not working in parallel’ is closed to new replies.
