UDF macro to get the liquid fraction when using the solidification & melting model
    • admin
      In the Fluent solidification & melting model, the liquid fraction can be accessed in the udf using the following macro: CLIQF(c,t) c, t is the following variables, respectively: cellt: c Thread: *t C_LIQF is available only in fluid cells and only if solidification is turned ON
    • admin
      Is there a UDF macro to get the liquid fraction when using the solidification & melting model?
    • samir12344321
      i have multiphase (vof) and solidification models. but can not see liquid fraction in post-processing.
    • DrAmine
      You will see it if you choose the phase where solidification or melting occurs.
    • samir12344321
      In the results of Ansys fluent 16.2,  I can see the liquid fraction of the solidification/melting process, but in cfd-post there is no entry for solidification/melting in the drop-down list. kindly help me
    • DrAmine
      You need to export it explicitly. Go File Export Solution and the rest is intuitive.
Viewing 5 reply threads
  • The topic ‘UDF macro to get the liquid fraction when using the solidification & melting model’ is closed to new replies.
