April 12, 2023 at 9:52 pm
April 13, 2023 at 1:41 pm
Forum ModeratorHave a look at the two tutorials in Help. I'm not sure if they use UDFs, but the general set up is covered. You then add the UDF to whichever setting you want to adjust: it may be a constant in the tutorial.Â
April 13, 2023 at 2:45 pm
Konstantin
Ansys EmployeeÂ
DEFINE_GC_MOTION is the right UDF implementation for this. I see some variables are not defined in your UDFs. Are they defines somewhere else? Is there anything that is not working in this UDF? There is a video on using DEFINE_CG_MOTION with oversets:
https://www.youtube.com/watch?v=BO2e9_njh5g
Hope this helps.
- The topic ‘UDF Implementation for overset mesh case’ is closed to new replies.
