February 8, 2024 at 9:19 am
nicolo varallo
SubscriberGood morning to everyone.
I am simulating the flow field in a cylindrical 3D bubble column using the Eulerian-Eulerian approach.
I need to define a drag coefficient that depends on the distance from the wall. My idea was to use the C_CENTROID macro to calculate the distance from the column centre and consequently define the drag coefficient, but it did not work.
Can anyone help me?
In the following, how I calculate the spatial coordinate to define the dependency of the drag coefficient on the radial coordinate.
begin_c_loop_all(c,t)
    C_CENTROID(xc,c,t);
    r=pow(xc[0]*xc[0]+xc[2]*xc[2],0.5); //distance from the column centre. The coordinate y is the column axis
    CD= a*r // just an example
end_c_loop_all(c,t)Â
February 8, 2024 at 9:50 am
Forum ModeratorIt's not compiling, giving an error or giving the wrong answer? "Not working" isn't that precise! :)Â
February 8, 2024 at 10:00 am
nicolo varallo
SubscriberSorry for that. It gives the wrong answer; the compilation is ok.
I obtain a constant coefficient without any spatial dependency.
February 8, 2024 at 12:03 pm
Forum ModeratorLooking at https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v241/en/flu_udf/flu_udf_MultiphaseDEFINE.html%23flu_udf_sec_define_exchange_property I don't know if you need the cell loop.Â
February 8, 2024 at 4:58 pm
nicolo varallo
SubscriberThanks for you reply.
I tried without cell loop, but it is the same. I think the problem is related to the calculation of the distance from the wall. I implemented this simple udf to see if the C_CENTROID works as expected. The udf defines a drag coefficient equal to 3 if the axial coordinate is smaller than 2m, 5 otherwise:
#include "udf.h"#include "math.h"DEFINE_EXCHANGE_PROPERTY(WLL,c,t,i,j){Thread *t_a = THREAD_SUB_THREAD(t,j);Thread *t_w = THREAD_SUB_THREAD(t,i);real CD;real xc[ND_ND];real a=2;C_CENTROID(xc,c,t);real y=xc[1];Â Â Â Â if (y < a)Â Â Â Â Â Â {Â Â Â Â Â Â CD=3;Â Â Â Â Â Â }Â Â Â Â Â Â else if (y>a)ÂÂ Â Â Â Â Â {Â Â Â Â Â Â CD=5;Â Â Â Â Â Â }Âbegin_c_loop_int(c,t){C_UDMI(c,t,0)=CD;}end_c_loop_int(c,t)return CD;}ÂThe result obtained is wrong as the figure shows:The withe line corresponds to a distance from the column bottom of 2m.
February 8, 2024 at 5:13 pm
Forum ModeratorThe white line may be 2m from the column bottom but the UDF is looking at the y-coordinate. What range of y does Fluent show (Scale is a good way to check).Â
February 8, 2024 at 5:22 pm
nicolo varallo
SubscriberÂ
y is the axial coordinate, with y comprised between 0 and 2m, x between -0.12 and 0.12m and z between -0.12 and 0.12m.
The contour represents only the region of interest, not the whole geometry.
The problem is that the udf does not correctly compute the distance from the column’s bottom.
February 9, 2024 at 9:36 am
Forum ModeratorYou're not computing a distance, xc[1] is the y-coordinate. So if your domain is 0-2m in the y direction.Â
February 9, 2024 at 9:52 am
nicolo varallo
SubscriberWhy not? If the reference frame is (0,0,0) and coincides with the column bottom, the y-coordinate of each cell centre coincides with the distance of the cell centre from the column bottom.Â
February 9, 2024 at 10:01 am
Forum ModeratorReference frame isn't necessarily inside the domain. What is the minimum y coordinate in your mesh?Â
February 9, 2024 at 10:04 am
February 9, 2024 at 10:27 am
Forum ModeratorThanks - that's what I wanted to check. You're not working with "wall distance" as that's a different macro, and not useful here. Can you replot the contour and overlay the mesh?Â
February 9, 2024 at 10:47 am
February 9, 2024 at 2:18 pm
Forum ModeratorGet rid of the cell loop around the UDM.Â
February 9, 2024 at 2:31 pm
nicolo varallo
SubscriberNow it works. Thank you very much!
February 9, 2024 at 3:03 pm
Forum ModeratorI had to ask too!Â
- The topic ‘UDF for multiphase flow’ is closed to new replies.
5799
