September 9, 2024 at 12:51 pm
warhammer975
SubscriberHi!
2D task. There is an external stationary cylinder and an internal rotating cylinder (shaft). How to write UDF correctly for pumping a mass of air into the first wall cell near the shaft.
Any suggestions will be very helpful.
Thank you -
September 9, 2024 at 1:50 pm
Forum ModeratorFrom the boundary wall look at DEFINE_PROFILE and from a layer (or few) of cells it's DEFINE_SOURCE. For the latter it's generally easier if you have a separate cell zone.Â
September 9, 2024 at 2:02 pm
warhammer975
SubscriberUnfortunately, I'm a complete newbie in this matter. If you don't mind, can you explain this in more detail?
September 9, 2024 at 3:15 pm
Forum ModeratorBoundary conditions are used for a surface effect, ie an inlet/outlet/wall and the like. If you need to add (or remove) material from a cell zone (volume effect) then you need a source term. What effect are you trying to replicate? Have you done some/most of the tutorials as those will give you a good idea of how the solver works.Â
September 9, 2024 at 3:40 pm
warhammer975
SubscriberInitially, I wanted the mass flow to be evenly distributed across the entire surface of the inner cylinder (this cylinder must rotate at a given speed) into the gap between the cylinders.
September 9, 2024 at 4:57 pm
Forum ModeratorAnd continues here.Â
https://innovationspace.ansys.com/forum/forums/topic/rotating-and-mass-flow-inlet/
- The topic ‘UDF for mass-flow-inlet’ is closed to new replies.
5849
