May 9, 2022 at 1:48 pm
ManthanPatel
SubscriberHey I'm working on the simulation of the droplet impact on different surfaces
I need help with the udf code for the calculation of the dynamic contact angle
I'm using 2D axisymmetric model
I have written a udf code for that which is
#include "udf.h"
#include "mem.h"
/* Dynamic Contact UDF */
/* Enumerate UDM numbers */
enum{
VOF_G_X,
VOF_G_Y,
VOF_G_Z,
CONTACT_ANGLE,
CONTACT_N_REQ_UDM
#define VISCOSITY 0.001153
#define SURF_TENS 0.0727
#define static_Con_Ang 93.0
#define dyn_adv_Ang 108.0
#define dyn_rec_Ang 78.0
#define C_VOF_G_X(C,T)C_UDMI(C,T,VOF_G_X)
#define C_VOF_G_Y(C,T)C_UDMI(C,T,VOF_G_Y)
#define C_VOF_G_Z(C,T)C_UDMI(C,T,VOF_G_Z)
#define C_CONTACT_ANGLE(C,T)C_UDMI(C,T,CONTACT_ANGLE)
DEFINE_ADJUST(dynamic_contact, domain)
Thread *ct, *pct, *t0;/*pointer to the thread*/
Thread *ft;
cell_t c, c0;/*An integer data type that identifies a particular cell within a cell thread.*/
face_t f;/*An integer data type that identifies a particular face within a face thread*/
double theta_n;
real vel_re[ND_ND],Unit_tan[ND_ND], vof_n[ND_ND],VOF_Norm[ND_ND], vec_nw[ND_ND], vec_tw[ND_ND];
real A[ND_ND], Amag, VOF_Mag,Tan_Mag, veltan[ND_ND];
double f_Hoff_inverse, x_hoff, Ca;
int phase_domain_index = 1;/*The phase_domain_index can be used in UDFs to distinguish between the primary and secondary
phase-level threads. phase_domain_index is always assigned the value of 0 for the primary phaselevel thread*/
Domain *pDomain = DOMAIN_SUB_DOMAIN(domain, phase_domain_index);
/*to get the specific phase (or subdomain) pointer within the mixture domain*/
if (first_iteration)
/*first iteration is true only at the first iteration of a timestep*/
/*Check UDMs have been set up */
if (N_UDM < CONTACT_N_REQ_UDM)
Message0(" WARNING: Require at least %d UDMs to be set up for dynamic contact angle model. ", CONTACT_N_REQ_UDM);
return;
/*Calculate VOF gradient*/
Alloc_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_NULL); /* Primary storage of variables being calculated */
Scalar_Reconstruction(pDomain, SV_VOF,-1,SV_VOF_RG,NULL);
Scalar_Derivatives(pDomain,SV_VOF,-1,SV_VOF_G,SV_VOF_RG,Vof_Deriv_Accumulate);
/* Store VOF gradient in user memory */
thread_loop_c(ct, domain)
/* Simpler thread loop when you want to loop over all cell threads in a given domain */
if (FLUID_THREAD_P(ct))
/*to check whether a cell thread is a fluid thread returns 1 (or TRUE) if the thread that is passed is a fluid thread, and 0 (or FALSE) if it is not*/
pct = THREAD_SUB_THREAD(ct, phase_domain_index); /* Use this instead of pt [] */
begin_c_loop(c, ct)
ND_V(C_VOF_G_X(c, ct), C_VOF_G_Y(c, ct),C_VOF_G_Z(c, ct ),=,C_VOF_G(c, pct)); /* Set 3 components to a vector */
end_c_loop(c, ct)
/* Free memory used for VOF gradient */
Free_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_NULL);
/* Calculate wall contact angle and save to user memory */
thread_loop_f(ft, domain)
/* to loop over all face threads in a given domain.*/
if(THREAD_TYPE(ft) == THREAD_F_WALL) /* Mixture Thread and Wall */
t0 = THREAD_T0(ft);
/*used to identify cell threads that are adjacent to a given face f in a face thread t. THREAD_T0 expands to a function that returns the cell thread of a given face’s adjacent cell c0*/
if (FLUID_THREAD_P(t0)) /* Fluid Zone */
/* Set contact angle parameters according to the type of wall surface */
begin_f_loop(f, ft)
c0 = F_C0(f, ft);
/*used to identify cells that are adjacent to a given face thread t. F_C0 expands to a function that returns the index of a face’s neighboring c0 cell*/
/* Get flow velocity */
NV_D(vel_re ,= ,C_U(c0, t0), C_V(c0, t0), C_W(c0, t0));
F_AREA(A, f, ft) ; /* Area vector */
Amag = NV_MAG(A);
NV_S(A,/=,Amag);
/*A now holds outward face normal*/
NV_D(vof_n, =, C_VOF_G_X(c0, t0), C_VOF_G_Y(c0, t0 ), C_VOF_G_Z(c0, t0));
VOF_Mag=NV_MAG(vof_n);
if(VOF_Mag!=0.0)
NV_VS(VOF_Norm, =, vof_n, *, (1/VOF_Mag));
else
NV_VS(VOF_Norm, =, vof_n, *, (0.0));
/* vof along wall*/
NV_VS(vec_nw, =, A, *, NV_DOT( VOF_Norm, A)); /*normal relative velocity vector */
NV_VV(vec_tw, =, VOF_Norm, -, vec_nw); /* Tangent velocity direction vector */
Tan_Mag = NV_MAG(vec_tw);
if(Tan_Mag!=0.0)
NV_VS(Unit_tan, =, vec_tw, *, (1/Tan_Mag));
NV_VS(veltan, =, Unit_tan, *, NV_DOT( vel_re, Unit_tan));
else
NV_D(veltan, =, C_VOF_G_X(c0, t0), C_VOF_G_Y(c0, t0 ), C_VOF_G_Z(c0, t0));
/*Contact line direction*/
/*Receding : Calculate dynamic contact angle*/
if (NV_DOT(veltan, vof_n) > 0.0)
Ca = (VISCOSITY*(NV_MAG(veltan)))/SURF_TENS;
/*DRCA model*/
theta_n = ((pow((pow(((dyn_rec_Ang)*M_PI/180.0), 3) - 72.0*Ca),(1/3)))*180)/M_PI;
C_CONTACT_ANGLE(c0, t0) = theta_n ; /* deg */
else
/* Advancing : Calculate dynamic contact angle*/
/* Kistler’s model*/
f_Hoff_inverse = pow(((dyn_adv_Ang)*M_PI/180.0), 3)/72.0;
x_hoff = Ca + f_Hoff_inverse;
theta_n = ((acos(1.0 - (2.0*tanh(5.16*pow((x_hoff/(1.0 + 1.31*pow(x_hoff, 0.99))),0.706)))))*180)/M_PI;
C_CONTACT_ANGLE(c0, t0) = theta_n; /* [ degs ] */
end_f_loop (f, ft)
printf("Executed Adjust ");
DEFINE_PROFILE(contact_angle, t, i)
face_t f;
cell_t c0;
Thread *t0;
begin_f_loop(f, t)
c0 = F_C0(f ,t);
t0 = F_C0_THREAD(f , t );
F_PROFILE(f ,t ,i) = C_CONTACT_ANGLE(c0, t0); /* Angle within the liquid in degrees */
end_f_loop(f, t)
DEFINE_EXECUTE_AFTER_CASE(set_name, libname )
Message0 (" Setting UDM names . . . ");
Set_User_Memory_Name(VOF_G_X,"VOF Gradient−x");
Set_User_Memory_Name(VOF_G_Y,"VOF Gradient−y");
Set_User_Memory_Name(VOF_G_Z,"VOF Gradient−z ");
Set_User_Memory_Name(CONTACT_ANGLE," Contact Angle [deg]");
Message0 ("Done. ") ;
But I'm getting an error after loading the udf and assigning the DEFINE_ PROFILE udf
the error is following
Node 0: Process 23624: Received signal SIGSEGV.
999999: mpt_accept: error: accept failed: No error
The fl process could not be started.
Please help me out, I'm new with these udfs
May 9, 2022 at 2:06 pmRob
Forum ModeratorIt's passed the compilation stage, so the "grammar" bit is right. How many UDM did you assign?
May 10, 2022 at 11:52 amManthanPatel
SubscriberHey Rob thanks for the comment
I assigned 4 UDM
May 10, 2022 at 4:17 pmRob
Forum ModeratorThat's the obvious problem passed. Not sure then. Try reporting the UDMs rather than using them to see if they have a finite value.
May 10, 2022 at 5:48 pmManthanPatel
Subscriberok I'll try that
Viewing 4 reply threads- The topic ‘UDF for Dynamic contact angle’ is closed to new replies.
3572
1188
1076
1063
952
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
