UDF for convection is not working
    • iitdhn.a
      hi, I want to apply convention boundary condion on a wall as a functin of varing ambient temperature. I have written a udf for free stream temperature (ambient) as funciton of time but it has unexpected effect in the convection boundary condition at the wall. when I am changing the temperature value in the udf it has no effect on solution. but for expression and as constant free stream temperature it works fine.
      I assume you've got DEFINE_PROFILE returning a temperature in Kelvin and hooked into the highlighted box below?
    • iitdhn.a
      Tahnks you for the reply!
      I used the following udf code to define varing ambient temperature and the unit I used in degree C
      DEFINE_PROFILE(ambient_temperature_profile, t, i)
          real time = CURRENT_TIME;
          real hour = time / 3600.0;
          real temp;
          face_t f;
          while (hour >= 24.0)
              hour -= 24.0;
          if (hour >= 8.0 && hour <= 13.0)
              temp = -20.0 + ((0.0 + 20.0) / 5.0) * (hour - 8.0);  // -20°C → 0°C
          else if (hour > 13.0 && hour <= 18.0)
              temp = 0.0 - (15.0 / 5.0) * (hour - 13.0);  // 0°C → -15°C
          else if (hour > 18.0 && hour < 24.0)
              temp = -15.0 - (5.0 / 6.0) * (hour - 18.0);  // -15°C → -20°C
          else
              temp = -20.0;  // Constant at night (midnight → 8 AM)
          begin_f_loop(f, t)
              F_PROFILE(f, t, i) = temp;
          end_f_loop(f, t)
      Alter to Kelvin, UDFs use SI units regardless of other settings. Also avoid the arrow symbols in comments, they should be OK but there’s a risk Fluent will see it as something else because of the UNIX legacy.
      To add, given flow timescales of under a second, and your code being hours you may want to review just how long you intend this model to run for.
