December 8, 2020 at 11:11 pm
heisenmech
SubscriberHi all,nI've checked almost all sources on how to get rid of the udf error below. All of the suggested methods are for typical udf compilation remedies, environment variables etc. nI've other udfs that are very similar to the current one, and are compiled smoothly. nI cannot share the code due to potential confidentiality issues, unfortunately. nI'd like to know if anyone had the same error with udf compilation, and found a way out.nMany thanks.nError:nnCreating library libudf.lib and object libudf.expnudf1st.obj : error LNK2019: unresolved external symbol max referenced in function source_knlibudf.dll : fatal error LNK1120: 1 unresolved externalsn -
December 9, 2020 at 12:46 am
heisenmech
SubscriberIt was a dumb mistake with math symbols. Converting symbols to CAPITAL has solved the issue.n -
December 9, 2020 at 2:31 pm
karthik.remella
AdministratorHi,nI'm glad you were able to resolve this issue. And thank you for sharing this resolution with the rest of us on the forum.nThanks.nKarthikn
- The topic ‘UDF Error – Ulibudf.dll : fatal error LNK1120: 1 unresolved externals’ is closed to new replies.
