November 22, 2024 at 2:53 am
sjohn
SubscriberI wrote the following UDF for heteregeneous reactions in a case for multiphase flow.Â
#include "udf.h"Â/* Define constants */#define R 1.987/* Universal gas constant in cal/(mol*K) */#define Pre 1/* Pre-exponential factor in m^3/(mol*s) */#define EA 5000/* Activation energy in cal/mol */Â/* Define phase indices */#define liquid_index 3/* Index for liquid phase */#define gas_index 2/* Index for gas phase B */Â/* Heterogeneous reaction rate definition */DEFINE_HET_RXN_RATE(sj_reaction_rate, c, t, r, mw, yi, rr, rr_t){  /* Get the temperature of the liquid phase */  real T_liquid = C_T(c, t); /* Temperature in K */  /*Calculate the concentration of A in the liquid phase */  real A_conc = C_YI(c, t, liquid_index);  /* Calculate the reaction rate */  *rr = Pre * exp(-EA / (R * T_liquid)) * A_conc;  /* Optional: Store additional information if needed */  C_UDMI(c, t, 0) = Pre; /* Store pre-exponential factor */  C_UDMI(c, t, 1) = EA; /* Store activation energy */  C_UDMI(c, t, 2) = R; /* Store gas constant */  C_UDMI(c, t, 3) = T_liquid; /* Store temperature */}ÂI am getting the following warning upon compiling my UDF with the built-in compiler.
 scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly
File "C:\Users\....\libudf\win64\3ddp_host\SConstruct", line 20, in
Compiler path: "C:\PROGRA~1\ANSYSI~1\v241\fluent"\ntbin\clang\bin\clang-cl
Linker  path: "C:\PROGRA~1\ANSYSI~1\v241\fluent"\ntbin\clang\bin\lld-link
After compiling, I click load and then initialize and run the simulation. Then I get a fatal error:
 Node 1: Process 6996: Received signal SIGSEGV.
 Node 2: Process 27464: Received signal SIGSEGV.
 Node 0: Process 26448: Received signal SIGSEGV.
 Node 3: Process 10824: Received signal SIGSEGV.
 Error in the fluent (fl) process : ended abnormally
Other than checking the box for Setup Compilation Environment for UDF in Fluent Launcher, do I need to anything else?
ÂÂ -
November 22, 2024 at 2:55 am
sjohn
SubscriberI also tried not using the built in compiler (after deleting the libudf folder) but get athe following error messages:
Compiler and linker: Microsoft Visual C++
# Generating ud_io1.h
simple_reaction.c
# Generating udf_names.c because of makefile simple_reaction.obj
udf_names.c
# Linking libudf.dll because of makefile user_nt.udf udf_names.obj simple_reaction.obj
LINK : fatal error LNK1104: cannot open file 'kernel32.lib'
NMAKE : U1077: 'link -nologo /Libpath:"C:\PROGRA~1\ANSYSI~1\v241\fluent"\fluent24.1.0\win64\3ddp_node /Libpath:"C:\PROGRA~1\ANSYSI~1\v241\fluent"\fluent24.1.0\multiport\win64\mpi\shared /dll /out:libudf.dll udf_names.obj simple_reaction.obj mport.lib fl_mpi2410.lib ' : return code '0x450'
Stop.
Done.
BSSPF3F1PZG: Opening library "C:\Users\...\libudf"...
ERROR: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).
The system cannot find the file specified.
C:\\Users\\...\\libudf\\win64\\3ddp_host\\libudf.dll
Done.
Error: An error occurred in the previous operation.
 The details can be found in the text output.
Error Object: #f
6660
1313
