September 20, 2020 at 4:43 am
yash54321
SubscriberHi,
Please find attached images for error messages. Here, I tried to compile the customizable UDF from ANSYS fluent manual.
I used "in-built compiler" and "MS Visual studio19 compiler (trying all available answers)".
The errors are either "'C:UsersyashrDesktopansystutsansystuts_filesdp0FFFFluentlibudfwin642ddp_node>C:PROGRA~1ANSYS Incv202fluent/../commonfiles/CPython/3_7/winx64/Release/python/scons C:PROGRA~1ANSYS' is not recognized as an internal or external command, operable program or batch file." OR "(chdir "libudf")(chdir "win642ddp_node")'nmake' is not recognized as an internal or external command, operable program or batch file."
Also, I didn't find option to start fluent 2020R2 in serial mode. Resulting in "The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64)." error.
September 21, 2020 at 1:41 amKarthik Remella
AdministratorTry launching Fluent using the -t0 flag. Change total number of processors to 0 and see if this alleviates the issue you are seeing.
It is also possible that the MS visual studio is not installed correctly on your computer. Please double check if this is done correctly.
You could also try to 'Use the In-Built Compiler' option in Fluent 2020R2.
Thanks.
Karthik
September 26, 2020 at 12:32 amyash54321
SubscriberThe fluent does not let me start using 0 processors. Also, I used 'in-built compiler' but doesn't work (as mentioned in the question). Thanks for your suggestions.
September 28, 2020 at 10:58 amRob
Forum Moderatornmake means there isn't an external compiler (typically Microsoft). I'm not sure why the built in compiler is failing though, does it run when you launch Fluent outside of Workbench. The lack of parallelisation of the code may mean the result isn't correct but doesn't normally stop the compiler from working.
October 30, 2020 at 4:01 pmattiq
SubscriberFacing Same Issue
January 6, 2021 at 4:44 pmelwinxavier
SubscriberI'm facing the same issue here. Any known solution?
January 6, 2021 at 5:00 pmRob
Forum ModeratorHave you tried launching outside of Workbench?
January 6, 2021 at 5:30 pmattiq
SubscriberI tried changing the version of MS Visual Studio and Tried running or opening fluent through RUN PROMPT. But every time I open I had to do it through VS Run Prompt. The problem is partially solved. Even through VS run prompt, sometimes fluent fails to load UDF. But sometimes it works fine.
Experts advice is still needed.
Thank You.
January 6, 2021 at 5:33 pmelwinxavier
SubscriberYa, even outside workbench I failed too. I used Built-in Compiler btw.
This is the error when i press "build"
"'C:\PROGRA~1\ANSYS' is not recognized as an internal or external command operable program or batch file."
January 6, 2021 at 5:37 pmattiq
SubscriberOpen This link. Try this way
January 6, 2021 at 5:40 pmelwinxavier
SubscriberThanks Attiq. I Watched this before. Tried and doesnt help.
January 6, 2021 at 5:50 pmelwinxavier
SubscriberI used Build-In Compiler and also tried both inside Workbench and outside workbench.
I'm getting error "'C:\PROGRA~1\ANSYS' is not recognized as an internal or external command, operable program or batch file."
Where is this directory of "C:\PROGRA~1\ANSYS" tho?
I'm not sure warning should be ignore? but if I continue to Load it, it will become
"Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).\n\nThe system cannot find the file specified."
January 7, 2021 at 2:30 amJD_JN
SubscriberHello As I had commented on an earlier similar post, I had the same issue and this is how I fixed it. Following these steps, you don't have to launch fluent from command prompt!
Install Visual Studio 2017 Community Edition with C++ options (ANSYS 2019 doesn't support newer versions of VS such as MSVS 2019)
Go to Control Panel -> System and Security -> System -> Advanced System Settings -> Environment Variables
Go to the bottom section named 'System variables' and then double-click to open "Path"
There, create 4 new entries (mentioned below as steps 5, 6, 7, 8) by clicking on 'New':
%SystemRoot%\system32
%SystemRoot%
C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\Hostx64\x64 (This is the location for "nmake" in MSVS 2017 Community Edition)
:\ \ANSYS Inc\v194\fluent\ntbin\win64 (This is for ANSYS 2019, your version number will change according to the one you have installed)
Make sure that the entries in steps 5 - 8 are at the top most rows of the path variables, i.e., entry 5 should be in row 1, entry 6 should be in row 2, entry 7 should be in row 3, and entry 8 should be in row 4. You can change their row positions using "Move Up" option in the system variables dialog box
Click OK and exit out of the Path variables dialog box, as well as exit out of the Environment variables dialog box and System properties dialog box
Restart system
Start FLUENT. In the FLUENT Launcher, click on 'Show More Options'
Make sure that the working directory location is the location of your folder containing your UDF and then click OK to launch FLUENT
Now you will be able to build and load your UDFs.
Hope this will also help in your issue.
Cheers!
January 7, 2021 at 7:14 amKeyur Kanade
Ansys EmployeeJanuary 7, 2021 at 9:54 amelwinxavier
Subscriberappreciate the kind help. Unfortunately these doesn't help.
My problem aren't really nmake. I'm using 2020 R2, I have the feature to enable "Built-In Compilers"
So the problem Statement is, when in Compiled UDFs
Built will result following Error
LOAD will result following Error
Do ANSYS staff knows, with Build-In Compiler, is the problem still lies within Visual Studio? Because if it doesn't we can certainly skip the MS Visual Studio and look other way.
Or the problem is more to the Build-in Compilers itself. Is there anyway to check on Build-In Compilers? DO we have any patch and installer to re-install on ANSYS Patch?
January 7, 2021 at 11:38 amRob
Forum ModeratorThe built in compiler should install with the rest of the code and is CLANG based so nothing linked to Microsoft VS. What is the full path of the installation and working folder?
January 7, 2021 at 11:53 amViewing 16 reply threads- The topic ‘UDF compilation problem in ANSYS Fluent 2020 R2’ is closed to new replies.
5669
1890
1419
1304
