February 20, 2025 at 9:53 pm
seijieng
SubscriberIn Rocky 2025 R1 for the Leeds Contact module, the equation in the module manual doesn't match the source code downloaded from the modules add-on. In the code, s_dot rather than sqrt(s_dot) is used.ÂEquation 16-7ÂF = 2*eta*sqrt(m*K*s_dot)Âdouble damping_coefficient = leeds_material_interaction.damping_ratio * 2.0 * sqrt(equivalent_mass * elastic_stiffness);
damping_force = damping_coefficient * (overlap - previous_overlap) / contact.get_timestep(); -
February 21, 2025 at 1:50 pm
Lucas Bertollo Baggio
Ansys EmployeeHello,
there is a typo in the documentation. It will be corrected, thanks. The equation 16-7 should be as it is in the source code.Â
