September 12, 2025 at 4:14 am
September 12, 2025 at 11:52 am
Federico
Ansys EmployeeHello,Â
can you show how you have set up your Dynamic Mesh zones?
September 12, 2025 at 12:18 pm
September 17, 2025 at 12:04 pm
Petros
Ansys EmployeeCan you try adding at least 3 elements in the thickness of the solid region? Also try and see how the default of Unified Remeshing works before switching to Methods-Based Remeshing.
September 19, 2025 at 4:07 am
Swapnil
SubscriberI tried with a refined mesh, but the issue still persists.Â
September 19, 2025 at 8:06 pm
Emmanuel-akor
SubscriberHi Swapnil, Your deformation values seems small so you shouldnt see high distortion. Your deformation result might be autoscaled. If you change the scale to 1 somewhere at the top menu, you should be fine. I've had this problem in the past with my FSI and thought I was doing something wrong.
September 22, 2025 at 9:54 am
Swapnil
SubscriberHi Emmanuel, thank you for your response. The error showing "high distortion in solid element" pops up in initial iterations itself. Therefore simulation is not complete.
5274
1859
1398
1257
