April 16, 2024 at 10:10 am
Swapnil
SubscriberHi,
I am facing this error while simulation two way FSI problem.
 "MAPDL is unable to connect to the system coupling service on DESKTOP-1TN19PS through port *****. Check the -schost and -scport options on the MAPDL command line in the System Coupling analysis and ensure that the host name and the port number are correct."
how to resolve this?Â
April 16, 2024 at 12:32 pm
Rahul
Ansys EmployeeHello Swapnil,
Which version are you using?
Is it specific to this case or happening with all the cases?
April 16, 2024 at 1:10 pm
Swapnil
SubscriberIt is working fine in 2020R1. But in recent 2023R1 and 2023R2 versions, it is showing the above error. Transient mechanical in standalone mode is working fine, the issue is in the case of co-simulations.
April 16, 2024 at 2:21 pm
Rahul
Ansys EmployeeAre you using VPN?
Sometimes restarting the system might help, have you tried restarting?
Also check if same issue observed with latest v241 version.
April 17, 2024 at 4:02 am
Swapnil
SubscriberNo, I am not using VPN.
I have restarted the system but it didn't work.
April 17, 2024 at 1:11 pm
Rahul
Ansys EmployeeOkay.Â
Please try setting this environment variable prior to starting System Coupling.
 ANSYS_RPC_LOCALACCESSONLY=1
Hope this helps!
April 18, 2024 at 7:00 am
Swapnil
SubscriberThank you. It worked for me.
But now it is showing below error
"The variable locations of force and heatflow variables for all Fluent    |
| participants are set to 'Node'. Make sure that this is consistent with the  |
| setup within Fluent. When importing the SCI file (this includes running   |
| inside Workbench), you can control the locations of these variables by    |
| using the 'SYC_FLUENT_CONSNODAL' environment variable" -
April 18, 2024 at 7:07 am
Rahul
Ansys EmployeePlease share detailed log file.
April 18, 2024 at 7:16 am
Rahul
Ansys Employeeit is recommended that you build up to the final two-way analysis incrementally, progressively adding complexity with each step. Check if your participant solutions works fine with representative loads. Look at the transcript files for errors if any.
Please refer Building a Coupled FSI Analysis from Decoupled Participant Problems (ansys.com).
April 18, 2024 at 9:25 am
Swapnil
SubscriberÂThis file may contain appended logs from a sequence of runs, with the mostrecent output reported at the end of the file.Â===============================================================================Transcript output started: 2024-04-18 12:28:20ÂÂ===============================================================================+=============================================================================+|                                       ||             Summary of Coupling Setup             ||                                       |+=============================================================================+===============================================================================Â+=============================================================================+|             Coupling Participants (2)             |+=============================================================================+|                                       || Participant: Fluent                             ||  Type :                              FLUENT ||  UpdateControls:                             ||    Option :                      ProgramControlled ||  Region: artery_wall                           ||    Topology :                          Surface ||    Input Variables :                    displacement ||    Output Variables :                       force ||  Variable: displacement                          ||    Quantity Type :               Incremental Displacement ||    Location :                            Node ||    Tensor Type :                         Vector ||    Is Extensive :                         False ||    Data Type :                           Real ||  Variable: force                             ||    Quantity Type :                         Force ||    Location :                            Node ||    Tensor Type :                         Vector ||    Is Extensive :                          True ||    Data Type :                           Real ||                                       |+-----------------------------------------------------------------------------+|                                       || Participant: Transient Structural                      ||  Type :                               MAPDL ||  UpdateControls:                             ||    Option :                      ProgramControlled ||  Region: System Coupling Region                      ||    Topology :                          Surface ||    Input Variables :                Force, Force_Density ||    Output Variables :              Incremental_Displacement ||  Variable: Force                             ||    Quantity Type :                         Force ||    Location :                            Node ||    Tensor Type :                         Vector ||    Is Extensive :                          True ||    Data Type :                           Real ||  Variable: Incremental_Displacement                    ||    Quantity Type :               Incremental Displacement ||    Location :                            Node ||    Tensor Type :                         Vector ||    Is Extensive :                         False ||    Data Type :                           Real ||                                       |+=============================================================================+|               Analysis Control                |+=============================================================================+|                                       || Analysis Type :                          Transient || Global Stabilization :                         None || OptimizeIfOneWay :                          False || AllowSimultaneousUpdate :                       False || PartitioningAlgorithm :               SharedAllocateMachines ||                                       |+=============================================================================+|              Coupling Interfaces (1)              |+=============================================================================+|                                       || Interface: interface-1                           ||  Side: One                                ||    Coupling Participant :              Transient Structural ||    Region List :                 System Coupling Region ||    Reference Frame :                GlobalReferenceFrame ||  Side: Two                                ||    Coupling Participant :                     Fluent ||    Region List :                       artery_wall ||    Reference Frame :                GlobalReferenceFrame ||  Data Transfer: Data Transfer                       ||    Suppress :                           False ||    Target Side :                           Two ||    Source Variable :              Incremental_Displacement ||    Target Variable :                    displacement ||    Unmapped Value Option :                 Nearest Value ||    Mapping Type :               Surface Profile Preserving ||    Convergence Target :                     1.00E-02 ||    Ramping Option :                         None ||    Relaxation Factor :                     8.00E-01 ||  Data Transfer: Data Transfer 2                      ||    Suppress :                           False ||    Target Side :                           One ||    Source Variable :                        force ||    Target Variable :                        Force ||    Mapping Type :                  Surface Conservative ||    Convergence Target :                     1.00E-02 ||    Ramping Option :                         None ||    Relaxation Factor :                     6.00E-01 ||  Mapping Control:                             ||    Absolute Gap Tolerance :                   0.0 [m] ||    Face Alignment :                  ProgramControlled ||    Poor Intersection Threshold :                5.00e-01 ||    Relative Gap Tolerance :                   1.00e+00 ||    Stop If Poor Intersection :                   True ||                                       |+=============================================================================+|               Solution Control                |+=============================================================================+|                                       || Duration Option :                          EndTime || End Time :                             0.2 [s] || Maximum Iterations :                           15 || Minimum Iterations :                           1 || Time Step Size :                         0.0002 [s] ||                                       |+=============================================================================+|                Output Control                |+=============================================================================+|                                       || Output Control Option :                      LastStep || Results                                   ||  IncludeInstances :                   ProgramControlled ||  Option :                               Off || Write Initial Snapshot :                        True ||                                       |+=============================================================================+Â+-----------------------------------------------------------------------------+| Warnings were found during data model validation.              |+-----------------------------------------------------------------------------+| Warning: Participant Transient Structural (CouplingParticipant:Solution 1) ||   has the ExecutionControl 'Option' set to 'ExternallyManaged'. System  ||   Coupling will not control the startup/shutdown behavior of this     ||   participant.                              || Warning: Participant Fluent (CouplingParticipant:Solution) has the     ||   ExecutionControl 'Option' set to 'ExternallyManaged'. System Coupling  ||   will not control the startup/shutdown behavior of this participant.   |+-----------------------------------------------------------------------------+ÂÂÂ+-----------------------------------------------------------------------------+| The variable locations of force and heatflow variables for all Fluent    || participants are set to 'Node'. Make sure that this is consistent with the || setup within Fluent. When importing the SCI file (this includes running   || inside Workbench), you can control the locations of these variables by   || using the 'SYC_FLUENT_CONSNODAL' environment variable. For more       || information, refer to System Coupling User's Guide.             |+-----------------------------------------------------------------------------+Awaiting connections from coupling participants...Transcript output stopped: 2024-04-18 12:28:25===============================================================================Â
April 18, 2024 at 9:27 am
Swapnil
Subscriber NUMBER OF WARNING MESSAGES ENCOUNTERED=     0 NUMBER OF ERROR  MESSAGES ENCOUNTERED=     1Â+——————— M A P D L  S T A T I S T I C S ————————+ÂRelease: 2023 R1      Build: 23.1    Update: UP20221128  Platform: WINDOWS x64ÂDate Run: 04/18/2024  Time: 12:28   Process ID: 2956Operating System: Windows 10 (Build: 19045)ÂProcessor Model: 12th Gen Intel(R) Core(TM) i7-12700ÂCompiler: Intel(R) Fortran Compiler Version 19.0.5 (Build: 20190815)     Intel(R) C/C++ Compiler Version 19.0.5 (Build: 20190815)     Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191125     BLAS Library supplied by Intel(R) MKLÂNumber of machines requested      :  1Total number of cores available     :  20Number of physical cores available   :  12Number of processes requested      :  4Number of threads per process requested :  1Total number of cores requested     :  4 (Distributed Memory Parallel)       ÂMPI Type: INTELMPIMPI Version: Intel(R) MPI Library 2021.5 for Windows* OSÂÂGPU Acceleration: Not RequestedÂJob Name: file0Input File: dummy.dat Core        Machine Name  Working Directory —————————————————–   0       DESKTOP-1TN19PS  F:\Two way FSI\_ProjectScratch\ScrDA12   1       DESKTOP-1TN19PS  F:\Two way FSI\_ProjectScratch\ScrDA12   2       DESKTOP-1TN19PS  F:\Two way FSI\_ProjectScratch\ScrDA12   3       DESKTOP-1TN19PS  F:\Two way FSI\_ProjectScratch\ScrDA12ÂLatency time from master to core   1 =  2.043 microsecondsLatency time from master to core   2 =  2.096 microsecondsLatency time from master to core   3 =  3.560 microsecondsÂCommunication speed from master to core   1 = 13728.96 MB/secCommunication speed from master to core   2 = 14491.18 MB/secCommunication speed from master to core   3 = 10225.86 MB/secÂTotal CPU time for main thread          :    1.2 secondsTotal CPU time summed for all threads       :    1.0 secondsÂElapsed time spent obtaining a license      :    0.3 secondsElapsed time spent pre-processing model (/PREP7) :    0.0 secondsElapsed time spent solution – preprocessing    :    0.0 secondsElapsed time spent computing solution       :    0.0 secondsElapsed time spent solution – postprocessing   :    0.0 secondsElapsed time spent post-processing model (/POST1) :    0.0 secondsÂÂSum of memory used on all processes        :    17.0 MBSum of memory allocated on all processes     :   5184.0 MBPhysical memory available             :     32 GBÂTotal amount of I/O written to disk        :    0.0 GBTotal amount of I/O read from disk        :    0.0 GBÂ+—————— E N D  M A P D L  S T A T I S T I C S ——————-+ *—————————————————————————–* |                                       | |                RUN COMPLETED                 | |                                       | |—————————————————————————–| |                                       | | Ansys MAPDL 2023 R1     Build 23.1     UP20221128  WINDOWS x64  | |                                       | |—————————————————————————–| |                                       | | Database Requested(-db)   1024 MB   Scratch Memory Requested  1024 MB | | Max Database Used(Master)   1 MB   Max Scratch Used(Master)   1 MB | | Max Database Used(Workers)   1 MB   Max Scratch Used(Workers)   4 MB | | Sum Database Used(All)     4 MB   Sum Scratch Used(All)    13 MB | |                                       | |—————————————————————————–| |                                       | |    CP Time   (sec) =     0.984    Time = 12:28:25     | |    Elapsed Time (sec) =     2.000    Date = 04/18/2024    | |                                       | *—————————————————————————–*Â
April 18, 2024 at 9:33 am
Rahul
Ansys EmployeeWhen running System Coupling and it stops running, the first thing to do is examine the output files for each solver to look for clues to what happened. For Fluent, look at the transcript .trn file. For Mechanical, look at the .out file. Also, look at the System Coupling log file, scl.
I recommend going over this tutorial in the Ansys documentation that shows a 2-way FSI simulation with Fluent and Mechanical. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/sysc_tut/sysc_tut_reedvalve_fluent.html
if this tutorial works well, consider checking your participant setups again to see if it is correctly defined.
April 18, 2024 at 12:15 pm
Swapnil
SubscriberI tried the reed valve FSI simulation from the manual, but it encountered the following.
system coupling log file gives " Awaiting connections from coupling participants..."
while on the console screen it is showing following...
===============================================================================+=============================================================================+|                                       ||             Summary of Coupling Setup             ||                                       |+=============================================================================+===============================================================================Â+=============================================================================+|             Coupling Participants (2)             |+=============================================================================+|                                       || Participant: Fluid Flow (Fluent)                      ||  Type :                              FLUENT ||  UpdateControls:                             ||    Option :                      ProgramControlled ||  Region: fsi                               ||    Topology :                          Surface ||    Input Variables :                    displacement ||    Output Variables :                       force ||  Variable: displacement                          ||    Quantity Type :               Incremental Displacement ||    Location :                            Node ||    Tensor Type :                         Vector ||    Is Extensive :                         False ||    Data Type :                           Real ||  Variable: force                             ||    Quantity Type :                         Force ||    Location :                          Element ||    Tensor Type :                         Vector ||    Is Extensive :                          True ||    Data Type :                           Real ||                                       |+-----------------------------------------------------------------------------+|                                       || Participant: MAPDL Transient                        ||  Type :                               MAPDL ||  UpdateControls:                             ||    Option :                      ProgramControlled ||  Region: FSIN_1_System Coupling Region                  ||    Topology :                          Surface ||    Input Variables :                Force, Force_Density ||    Output Variables :              Incremental_Displacement ||  Variable: Force                             ||    Quantity Type :                         Force ||    Location :                            Node ||    Tensor Type :                         Vector ||    Is Extensive :                          True ||    Data Type :                           Real ||  Variable: Incremental_Displacement                    ||    Quantity Type :               Incremental Displacement ||    Location :                            Node ||    Tensor Type :                         Vector ||    Is Extensive :                         False ||    Data Type :                           Real ||                                       |+=============================================================================+|               Analysis Control                |+=============================================================================+|                                       || Analysis Type :                          Transient || Global Stabilization :                         None || OptimizeIfOneWay :                           True || AllowSimultaneousUpdate :                       False || PartitioningAlgorithm :               SharedAllocateMachines ||                                       |+=============================================================================+|              Coupling Interfaces (1)              |+=============================================================================+|                                       || Interface: Coupling Interface 1                       ||  Side: One                                ||    Coupling Participant :              Fluid Flow (Fluent) ||    Region List :                           fsi ||    Reference Frame :                GlobalReferenceFrame ||  Side: Two                                ||    Coupling Participant :                MAPDL Transient ||    Region List :              FSIN_1_System Coupling Region ||    Reference Frame :                GlobalReferenceFrame ||  Data Transfer: Force                           ||    Suppress :                           False ||    Target Side :                           Two ||    Source Variable :                        force ||    Target Variable :                        Force ||    Mapping Type :                  Surface Conservative ||    Convergence Target :                     1.00E-02 ||    Ramping Option :                         None ||    Relaxation Factor :                     1.00E+00 ||  Data Transfer: displacement                       ||    Suppress :                           False ||    Target Side :                           One ||    Source Variable :              Incremental_Displacement ||    Target Variable :                    displacement ||    Unmapped Value Option :                 Nearest Value ||    Mapping Type :               Surface Profile Preserving ||    Convergence Target :                     1.00E-02 ||    Ramping Option :                         None ||    Relaxation Factor :                     1.00E+00 ||  Mapping Control:                             ||    Absolute Gap Tolerance :                   0.0 [m] ||    Face Alignment :                  ProgramControlled ||    Poor Intersection Threshold :                5.00e-01 ||    Relative Gap Tolerance :                   1.00e+00 ||    Stop If Poor Intersection :                   True ||                                       |+=============================================================================+|               Solution Control                |+=============================================================================+|                                       || Duration Option :                          EndTime || End Time :                             1.00e-02 || Maximum Iterations :                           10 || Minimum Iterations :                           1 || Time Step Size :                          1.00e-04 ||                                       |+=============================================================================+|                Output Control                |+=============================================================================+|                                       || Output Control Option :                      EveryStep || Results                                   ||  IncludeInstances :                   ProgramControlled ||  Option :                        ProgramControlled ||  Type                                   ||    Option :                         EnsightGold || Write Initial Snapshot :                        True ||                                       |+=============================================================================+Â+=============================================================================+|              Execution Information              |+=============================================================================+|                                       || System Coupling                               ||  Command Line Arguments:                          ||   --guiserver -m cosimgui                         ||  Working Directory:                            ||   F:\ReedValve                              ||                                       || Fluid Flow (Fluent)                             ||  Execution Command:                            ||   "C:\PROGRA~1\ANSYSI~1\v231\fluent\ntbin\win64\fluent.exe" 3ddp -g -scpo ||   rt=56975 -schost=localhost -scname="Fluent_1" -i Fluent_1.jou      ||  Working Directory:                            ||   F:\ReedValve\Fluent_1                          ||                                       || MAPDL Transient                               ||  Execution Command:                            ||   "C:\PROGRA~1\ANSYSI~1\v231\ansys\bin\winx64\ANSYS231.exe" -b nolist -s ||   noread -scport 56975 -schost localhost -scname "Mechanical_2" -i "Mecha ||   nical.dat" -o Mechanical_2.out                     ||  Working Directory:                            ||   F:\ReedValve\Mechanical_2                        ||                                       |+=============================================================================+Awaiting connections from coupling participants...Traceback (most recent call last): File "PyLib\kernel\remote\RemoteObjects.py", line 190, in CreateRemoteObject File "PyLib\cosimulation\remoteclient\Client.py", line 11, in __init__ File "pyExt\PhysicsCouplingAnsRpcWrapper.py", line 129, in __init__RuntimeErrorÂTraceback (most recent call last): File "PyLib\kernel\server\JsonRpc.py", line 196, in methodCallHandlerCore File "PyLib\kernel\server\JsonRpc.py", line 145, in impl File "PyLib\kernel\server\JsonRpc.py", line 48, in executeCommand File "PyLib\kernel\commands\CommandDefinition.py", line 75, in func File "PyLib\kernel\commands\__init__.py", line 30, in executeCommand File "PyLib\kernel\commands\CommandManager.py", line 165, in executeCommand File "PyLib\cosimulation\externalinterface\core\solver.py", line 137, in execute File "PyLib\cosimulation\solver\__init__.py", line 151, in solve File "PyLib\kernel\util\Memory.py", line 209, in wrapper File "PyLib\cosimulation\solver\__init__.py", line 550, in __startParticipantsControlled File "PyLib\cosimulation\participantmanager\couplingparticipant\OldApisParticipant.py", line 137, in completeParticipantSetup File "PyLib\cosimulation\participantmanager\couplingparticipant\OldApisParticipant.py", line 378, in __reachInitialSyncPoint File "PyLib\cosimulation\remoteclient\__init__.py", line 42, in setRequestKeyError: 'Fluent_1'
- The topic ‘Two way FSI’ is closed to new replies.
