July 10, 2024 at 4:16 pm
July 11, 2024 at 5:53 am
Amrita Pati
Ansys EmployeeHi Jie,
Are you calculating the BSDF from the files given in these 2 examples? I am supposing it could be the data format, as the 2nd one is supposed to be consistent with Spoes. But let me test it and get back to you.
Amrita -
July 11, 2024 at 3:46 pm
jie li
SubscriberYes, I downloaded both examples to calculate the BRDF of the surface, and I found that both have the same geometric modeling method. I tried to use the same parameters to simulation, but the BRDF results were wildly different.
I only changed the roughness to 0. and then the grid accuracy was reduced to level 1, the scanning azimuth was changed to 0 , and the index is3.84 (Si) , and the simulation results were as follows. the first come from "Bidirectional_scattering_distribution_function_(BSDF)"
The second figure from "Diffuse Scattering Film for Automotive Display", which has the same simulation parameters as the first, i got the result by clicking "run", and running the analysis script.
jie li
I only changed the roughness to 0. and then the grid accuracy was reduced to level 1, the scanning azimuth was changed to 0 , and the index is3.84 (Si) , and the simulation results were as follows. the first come from “Bidirectional_scattering_distribution_function_(BSDF)”
The second figure from “Diffuse Scattering Film for Automotive Display”, which has the same simulation parameters as the first, i got the result by clicking “run”, and running the analysis script.
- The topic ‘Two cases in the case base have different brdf calculation results.’ is closed to new replies.
5799
