June 30, 2023 at 3:29 pm
pegah.mehrabian
SubscriberHi everyone. For a two-way FSI simulation of flow over a cylinder, I defined four springs (body-to-ground) with similar stiffness in transient structural ANSYS. With the defined inlet velocity of flow in CFX, I expect to get the resonance amplitude in transient structural. But after 20 seconds, the simulation got diverged. In the result, it seems springs start twisting because of the nonlinearity of the problem. How could I solve this problem?
July 3, 2023 at 2:08 pm
dlooman
Ansys EmployeePerhaps add stiff torsional springs at the same four locations. You may need to turn on beta features.
July 3, 2023 at 2:47 pm
pegah.mehrabian
SubscriberWould you please explain more? like how could I add stiff torsional springs? or what do you mean by using beta features?
Thanks -
July 3, 2023 at 2:52 pm
July 3, 2023 at 5:24 pm
pegah.mehrabian
SubscriberThank you, I found it. How could I define torsional stiffness based on longitudinal stiffness, now? Could you please provide me with some formulas?
July 4, 2023 at 4:03 am
peteroznewman
SubscriberA rigid body has 6 degrees of freedom. Do you want the cylinder to move in all 3 translations and all 3 rotations?
The way you drew the springs, perhaps you only want the cylinder to translate in 2 directions: X and Y. If that is the case, add constraints to the structural model to fix the other 4 degrees of freedom. A simple way to add a General Joint. That has integral springs so you can delete the 4 springs you added.
July 5, 2023 at 3:27 pm
pegah.mehrabian
SubscriberIt works so well, thank you so much!
July 5, 2023 at 2:02 pm
dlooman
Ansys EmployeeIf you are trying to include a realistic representation of the spring's torsional stiffness that would be something a spring manufacturer might provide. I say "might" because springs typically aren't used to provide torsional stiffness.
July 5, 2023 at 3:25 pm
pegah.mehrabian
- The topic ‘Twist of springs’ is closed to new replies.
5934
1306
