April 10, 2023 at 5:53 pm
João Paulo de figueiredo da silva
SubscriberHello everyone,
I would like to know if exist a tutorial for ansys mechanical workbench which I can use to study the sintering process. I read the article below:
and in this present study consist to compare the numerical results with experimental in ceramic components. In general, the ideia is put the ceramic mass in the oven. During the oven time the maximum temperature is around 1200 Celsius degrees and the temperature activation is around 600 Celsius; So, in the end we have a deformation and retraction.Â
April 11, 2023 at 1:38 pm
Vinayak Vipradas
Ansys EmployeeHi,Â
Sintering process simulations in Mechanical are performed using the Sintering Process Add-on, which simplifies the setup of the sintering material model. An Additive Suite license is required to use the add-on.Â
For more information about sintering process, please refer to the follwing Ansys Help Document:
Sintering Simulation Guide (ansys.com)Â
Regards,Â
Vinayak Vipradas
- The topic ‘Tutorial workbench with sintering process;’ is closed to new replies.
5794
