May 29, 2024 at 7:41 pm
Wanz
SubscriberHey, i need help with turning operation in explicit dynamics and analyse temperature, We designed our tool where we kept the insert structured. Then, we designed the workpiece as a tube with a thickness of 2.5mm. After that, we did our assembly in SolidWorks. We tried explicit dynamics on ANSYS. But in the end, either the tool does not move, or if it does move, the workpiece gets deformed and chips are not removed. Or the tool goes inside the workpiece without doing any machining. Our main purpose is to note down temperature while the chips are being removed. Feed is to be kept constant of 0.1 mm/rev. And 9 variation of speed starting from 100m/min to 900m/min. tungsten base uncoated flat cemented carbide (material pf insert) and AISI/SAE 4140 high tensile alloy steel (material of workpiece). We set the end time of 0.005 sec and number of cycles we used were 1000 cycles. What end time and preferred number of cycles should we use to get 5mm length of cut, insert is not touching the wp and is almost at a minor distance of 1.13mm. I need urgent help. @peteroznewman
May 30, 2024 at 11:31 am
Ram Gopisetti
Ansys EmployeeHi Wanz,
Please check the procedure as described in the following linksÂ
https://www.youtube.com/watch?v=2cxqLX6R6GsÂ
https://www.youtube.com/watch?v=hF3QRNrdbgI
Cheers, RamÂ
May 30, 2024 at 11:40 am
Wanz
SubscriberÂ
I have watched both of these videos, but neither of them was helpful. Suggest me something else please
- The topic ‘Turning operation in explicit dynamics’ is closed to new replies.
