August 16, 2023 at 4:38 am
shahim.ha
Subscriberwhat settings of smoothing and remeshing we should take for turek hron case , so that we can avoid negative volume error.
August 16, 2023 at 2:37 pm
Federico
Ansys EmployeeHello,Â
What types of cells are you using in your mesh? Can you show a screenshot of your setup?
The default remeshing/smoothing methods should work fine for this case: unified remeshing with spring smoothing. Negative volume error can also occur if your time step is too large for the resulting displacement.
August 17, 2023 at 10:35 am
shahim.ha
Subscribertetra elements only, with smoothing and remeshing with time step .005 seconds
August 17, 2023 at 2:53 pm
Federico
Ansys EmployeeHow does this time step compare with the size of your elements near the moving boundary? Remember time step delta t <= mesh size/boundary velocity.
August 18, 2023 at 4:22 am
shahim.ha
Subscriberyes element size is .005 and velocity is 1.5m/s. time step is .001
August 18, 2023 at 3:41 pm
Federico
Ansys EmployeeTime step of 0.001s should be fine then, but 0.005s which you mentioned earlier would be too large. If the problem persists, please provide more details:
What are your remeshing settings?
How are your Dynamic Mesh zones set?
August 31, 2023 at 10:07 am
shahim.ha
Subscribereven with that also, I am not getting.
Remeshing- local cell , size interval 1, 0.7.
In dynamic zone interface , i had taken as system coupling and symmetry as deforming
August 31, 2023 at 1:15 pm
Federico
It is really difficult for me to provide specific recommendations if I don't have any visuals of your model or any reference to the zones that you mention.
You can read on the various Dynamic Mesh settings in the Fluent User Guide: 12.6. Using Dynamic Meshes (ansys.com)
- The topic ‘TUREK HRON case -Problem of negative error in this case’ is closed to new replies.
5799
