Turbulent Thermal Conductivity
    • david.bacci
      Hi all
      I am using ANSYS FLUENT to model heat transfer in a pipe with a low Pr gas
      Since the typical constant value of turbulent Prandtl = 0.85 is no longer valid in this situation, a custom UDF must be built
      I noticed that there are several DEFINE_PRANDTL UDFs, but I suppose the one I must target is DEFINE_PRANDTL_T
      However, it seems that it is not doing exactly what I am telling him to do
      Is there a way to directly modify the turbulent conductivity or diffusivity, such as making it possible for turbulent viscosity?
      Thanks
      David
    • Rajat Chaudhari
      H David,
      Fluent uses turbulent Prandtl number and turbulent viscosity value to calculate turbulent thermal conductivity part of effecttive conductivity.
      You can use DEFINE_PRANDTL and DEFINE_TURBULENT_VISCOSITY function to define it. To access turbulent thermal conductivity you can use  C_K_T(c,t,prt) macro.
