January 13, 2025 at 5:16 am
taegoon
SubscriberHello, i'm simulating the FSI simulation of the interaction between object (structural) and fluent (air).Â
I want to realize the turbulent flow for the inlet in the FSI simulation. I mean, the input wind in the simulation should applies the fluctuating pressure on the object, since the turbulent flow has varying direction and magnitude. I utilized a lot of viscous model in FLUENT such as, k-w and k-e, However, in transient simulation it seems laminar flow is applied from the inletÂ
how can i make the fluctuating wind(just like natural wind) which has varying magnituda and direction in FSI simulation?Â
January 13, 2025 at 10:13 am
Forum ModeratorYou'd need LES or similar to see any effect of the turbulence, but that's likely to be masked by the inherent transient effects of gusting. Have a think about your definitions and exactly what you're trying to determine.Â
4683
1565
1386
1242
