May 12, 2024 at 3:43 pm
abod jabali
Subscriber  I'm working right now on my bechelor thesis which is about cooling the turbine blade with new innovative mechanisms, i'm setting up a currently this blade with cooling passages to investigate the blade when only cooling passages and film cooling holes are only used as cooling mechanisms. later on i will be adding the new techniques which will be used in the blade, but in the scenario where only cooling passages and film cooling holes are only used the solution never proceeds and it stays as seen in the following pictureÂ
what can be the reason for the incorrect setup in this case ?
the modes that are used are viscous k-e and momentum for the simplicity at the beginning
boundary conditions are inlet and outlets for the gas from the gas domain
inlet from a single cooling passage hole from the bottom and outlets which will be multiple outlets going out from the film cooling holes and the the final cooling passage in the bottom of the tailÂ
walls and symmetry have been also defined for the blade and the domainÂ
but the solution is still not proceeding -
May 15, 2024 at 9:06 am
Bhargav Desai
Ansys EmployeeHi Abod,
Although it will be difficult to comment with available information, here is the reference which will help you with setting up a CHT simulation.
ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink - Ansys Knowledge
Additionally, you can perform following steps before starting the simulation:
- Perform mesh check and Check case,
- Make sure the boundary conditions applied are not conflicting.
- The topic ‘Turbine blade setup and solution’ is closed to new replies.
5664
1890
1419
1304
