November 20, 2024 at 9:03 pm
ALEXANDRE COSTA
SubscriberHello,
Can the experts tell how to access the TUI commands for the Fluent MPM model ? Unfortunatelly the documentation does not cover that detail.
Perusing the corresponding mpm addon.bin I found some variables, such as listed below :
(mpm-libname mpm-udf udf string-append mpm-create-mode?Â
quote boolean edit-inj-name ti-cmd-silent? ti-cmd silent? s? args cmd with-output-to-stringÂ
ti-menu-load-string format for-each var make-new-rpvar mpm? mpm-inj-data list mpm-use-bsp?Â
mpm-use-display-injection? mpm-display-out? mpm-use-soft-collision? mpm-injection-name stringÂ
mpm-inertial-momentum-factor real mpm-udm-offset integer mpm-use-markers-on-sphere?Â
mpm-max-number-of-points-on-sphere mpm-report-surface-area-ratio?Â
mpm-surface-area-option mpm-domain-extents real-list mpm-track-inter-contphase?Â
mpm-solve-temperature? mpm-orig-force-formulation? mpm-track-part-timesteps mpm-track-wt-fixvelÂ
mpm-track-zones integer-list mpm-drag-nodrag? mpm-drag-default? mpm-drag-morsi? mpm-drag-constant? ....et ceteraMy question is how to setup those variables.
Any expert advice is very very welcome.
Thanks.
November 21, 2024 at 10:31 am
Forum ModeratorThose are all Scheme level commands as the model is an add on feature that (mis)uses other elements of the code. As with some of the other add on modules there are no TUI commands available.Â
5649
1885
1404
1303
