September 17, 2020 at 7:58 pm
luist
SubscriberHow do I turn on the title display on the Graphics window by TUI commands on previous versions of Fluent? (2019R3,2019R2...)nThe command /preferences/appearance/titles yes are not available on those. -
September 17, 2020 at 9:31 pm
Surya Deb
Ansys EmployeeHello, nYou can use the command /display/set/titles nRegards,nSuryann -
September 17, 2020 at 10:23 pm
luist
SubscriberHi Sdeb,nBut this command set a string on determined location. like the image:n
What I need is the GUI display the titles which shows me some configurations of the case, like the image below:nn
If I perform the command / preferences / appearance / titles yes in 2020R2 version, the result is like the image aboven
September 17, 2020 at 11:23 pm
Surya Deb
Ansys EmployeeI see. Then can you please try this command?n/display/set/windows/text visible? yesnThis should turn it on.n -
September 18, 2020 at 12:42 am
luist
SubscriberIt worked!nThank you sdeb! n
Viewing 4 reply threads
- The topic ‘TUI command for title on latest version’s’ is closed to new replies.
