TUI command for adding Data File Quantities
    • desouzadacosta
      Does anyone know the TUI(not cx-...)  command for the attached figure?
    • SRP
      You need to change cff -files to No using TUI: /file> cff-files>no  then you can see the option of data file options under 'files'.
      Thank you.
    • desouzadacosta
      Thanks. Completely solved.
