TAGGED: #fluent-#ansys, #fluent-#cfd-#ansys, #mechanical-#workbench, ansys-fluent, ansys-fluent-meshing, ansys-fluent-solver, ansys-mechanical, ansys-mechanical-apdl, ansys-workbench-mechancal, ansysfluent, ansysmechanical, anys-mechanical, cfd-fluent, Explicit-VOF, fluent, fluent-coupling, fluent-mesh, Implicit-VOF, mechanical, multifluid-vof, one-way-coupling, system-coupling, systemcoupling, two-way-coupling, two-way-coupling-fluent, vof, vof-model, vof-multiphase, volume-of-fluid-vof
January 4, 2026 at 6:53 am
andres20992025
SubscriberI'm creating an example of water flow over a fully submerged structure in "Fluent". I'm interested in understanding the reactions at the base of the structure (for which I'll use "Mechanical").ÂFirst, I created some small models, testing with VoF (with a very small air height above the water flow) and others without VoF (trying to mimic the model with VoF). I made several different attempts in Fluent, trying to obtain results similar to the model with VoF. I managed to get similar reaction results in some directions, but in the direction perpendicular to the flow and for the moment in the flow direction, I obtained very different results. In all cases, I considered a "Velocity Inlet" for the inlet section, a "Wall" for the flow walls, and a "Pressure Outlet" for both the free surface and the flow outlet section (which is not a discharge, but an outlet from the control volume of a flow that continues beyond). In all cases, I defined the "Reference Pressure Location" at the free surface.ÂWhen I don't use VoF, I don't get the "Open Channel" options that I had with VoF, so I have to add a "Gauge Pressure" for the free surface and the outlet section. In the outlet section, I tried using a Gauge Pressure of 0 Pa and a hydrostatic pressure function, but in both cases, I got a significant difference between the reactions perpendicular to the flow direction and the moment in the flow direction compared to the case where I used VoF.ÂIs there any way to simulate VoF without using it? (I want to create a larger model later, and if I try to use VoF for this, I run into problems with file size [GB], my PC's capacity, and convergence in Fluent.) -
January 5, 2026 at 9:22 am
Forum ModeratorIf you don't need to see free surface effects you don't need a multiphase model.Â
Did you set the operating density to be precisely that of the liquid? If so just set a 0 Pa pressure on the outlet and it should be fine. With gravity off (fine for constant density) you can omit the operating density part.Â
January 6, 2026 at 2:33 am
andres20992025
SubscriberFor an FSI case, where there is flow around a solid (single-phase model in Fluent), should I set the operating density to zero in Fluent so that the hydrostatic pressure is considered within the total pressure on the solid?
January 6, 2026 at 9:41 am
Forum ModeratorDoes the hydrostatic pressure effect the flow or force? Ie hydrostatic head will compress something, but won't it still wobble based purely on the dynamic flow force?
4858
1587
1386
1242
