November 14, 2023 at 8:07 pm
gu694925
SubscriberMy apologies if this is not the correct forum to be asking this in.
I am very new to Ansys and I am trying to make a composite material out of glass fiber and polyurethane, possibly other polymers in the future. I am trying to use Ansys Material Designer in order to do this, but when I select the option for a woven material, it prompts "Specify MatML file". What do I do here? It seems like if I ignore it there are errors when trying to generate the geometry.
I couldnt find any tutorials that need to specify a MatML file, or very many Ansys Material Designer tutorials in the first place.Â
Any help would be appreciated.
November 16, 2023 at 12:31 pm
Ashish Khemka
Forum ModeratorHi, Please see if the following link helps: /forum/forums/topic/generate-material-library-from-an-excel-file-export-a-custom-material-library-to-colleagues/ Regards, Ashish Khemka -
November 27, 2023 at 10:38 pm
David Mercier
- The topic ‘Trying to create composite material in Material Designer’ is closed to new replies.
