December 5, 2023 at 12:51 am
crumberger
SubscriberI am attempting to recreate the Lumerical RCWA portion of the small metalens tutorial using only Lumerical scripting rather than starting from the pre-built .fsp example file. When scripting Lumerical, I am having trouble with the command:
addrcwa;
Yet, this command appears in the online knowledge base here.Â
If I choose to use the command "addfdtd;" instead of "addrcwa;" the line executes, but I get an error further down the script when using the command:
addsweepresult("thickness_sweep_script", result_1);
This seems strange to me because the code worked last week without errors when using the "addfdtd;" command.
A couple of notes:
1) I initially built this script with FDTD in mind but decided to try switching to RCWA since that is what appears in the online tutorial linked above. I realize that I may need to change some parts of my code accordingly. However, "addrcwa;" fails even when run as a lone command in the command window.
2) The screenshots above show the problematic lines being run alone in the command window. The errors are identical when running the full code. Only the line number in the error message changesI have included my code below. (I am still trying to work out how best to add sweeps and collect the results to get the phase response info, but that's another topic.) Thanks in advance for any advice!
SCRIPT:Âdeleteall;if(exist("cylinder_height_sweep")) {deletesweep("cylinder_height_sweep");}if(exist("cylinder_radius_sweep")) {deletesweep("cylinder_radius_sweep");}### VARIABLES #### Constants and Unitsnm = 1e-9;um = 1e-6;# Nanopillarheight_np_min = 600*nm;height_np_max = 1.2*um;radius_np_min = 75*nm;radius_np_max = 125*nm;material_np = "Si (Silicon) - Palik";# Substrateperiod = 400*nm;thick_sub = 100*nm;material_sub = "SiO2 (Glass) - Palik";# FDTDlda_min = 400*nm;lda_max = 800*nm;airgap = lda_max/2;#height_cell = height_np_max+thick_sub+2*airgap;zmin_cell = -1*(thick_sub + airgap);zmax_cell = height_np_max + airgap;Â# Cylindrical Nanopillaraddcircle;set("x",0);set("y",0);set("radius",radius_np_min);set("z min",0);set("z max",height_np_min);set("material",material_np);Â# Substrateaddrect;set("x",0);set("x span",period);set("y",0);set("y span",period);set("z min",-1*thick_sub);set("z max",0);set("material",material_sub);Â# FDTD Region#addrcwa;addfdtd;set("dimension",2); # 1 = 2D, 2 = 3Dset("x",0);set("x span",period);set("y",0);set("y span",period);set("z min",zmin_cell);set("z max",zmax_cell);set("x min bc","Periodic");set("y min bc","Periodic");set("pml profile",3); # 1. standard, 2. stabilized           # 3. steep angle, 4. customset("allow symmetry on all boundaries",true);set("set simulation bandwidth",true);set("simulation wavelength min",lda_min);set("simulation wavelength max",lda_max);set("always use complex fields",true);Â### Mesh Override Regionaddmesh;set("dx",10*nm);set("dy",10*nm);set("dz",10*nm);set("based on a structure",true);set("structure","circle");Â### Sourceaddplane;set("injection axis","z");set("x",0);set("x span",period);set("y",0);set("y span",period);set("z",zmin_cell);# If Frequency Domainset("wavelength start",lda_min);set("wavelength stop",lda_max);# Else if Time Domainset("set time domain",true);Â### Monitoraddpower;set("name","Transmission");set("monitor type","2D Z-normal");set("x",0);set("x span",period);set("y",0);set("y span",period);set("z",zmax_cell-airgap/2);Â### Parameter Sweep# create parameter sweep "height"addsweep;setsweep("sweep", "name", "cylinder_height_sweep");setsweep("cylinder_height_sweep", "type", "Ranges");setsweep("cylinder_height_sweep", "number of points", 10);# define the parameter heightpara_h = struct;para_h.Name = "height";para_h.Parameter = "::model::height";para_h.Type = "Length";para_h.Start = height_np_min;para_h.Stop = height_np_max;para_h.Units = "microns";addsweepparameter("cylinder_height_sweep", para_h);# define resultsresult_1 = struct;result_1.Name = "S";result_1.Result = "S";result_2 = struct;result_2.Name = "T";result_2.Result = "T";# add the results R & T to the sweepaddsweepresult("thickness_sweep_script", result_1);addsweepresult("thickness_sweep_script", result_2);Â# create parameter sweep "radius"addsweep;setsweep("sweep","name","cylinder_radius_sweep");# define the parameter radiuspara_r = struct;para_r.Name = "radius";para_r.Parameter = "::model::radius";para_r.Type = "Length";para_r.Start = radius_np_min;para_r.Stop = radius_np_max;para_r.Units = "microns";# add the parameters to the sweepaddsweepparameter("cylinder_height_sweep", para_r);# define resultsresult_1 = struct;result_1.Name = "R";result_1.Result = "::model::R::T";Âresult_2 = struct;result_2.Name = "T";result_2.Result = "::model::T::T";Â# add the results R & T to the sweepaddsweepresult("thickness_sweep_script", result_1);addsweepresult("thickness_sweep_script", result_2);Â
December 5, 2023 at 2:33 pm
Dimitris Polyzos
Ansys EmployeeHello,Â
Regarding the addrcwa; command it runs OK on my PC. Could you please let me know what version of Lumerical do you use? In the script you shared, I commented the addfdtd; command line and uncommented the addrcwa; and it works fine.
It seems that your script needs a slight modification in order to work. After loading it in script file editor please change at line 120 and 121.
addsweepresult("cylinder_height_sweep", result_1);
addsweepresult("cylinder_height_sweep", result_2);
Similarly do the same for lines 146Â and 147 for the name :
addsweepresult("cylinder_radius_sweep", result_1);
addsweepresult("cylinder_radius_sweep", result_2);
Otherwise, you can use the corrected script directly below:
deleteall;
### VARIABLES ###
nm = 1e-9;
um = 1e-6;
# Nanopillar
# Substrate
period = 400*nm;
thick_sub = 100*nm;
# FDTD
lda_min = 400*nm;
lda_max = 800*nm;
airgap = lda_max/2;
addcircle;
set("x",0);
set("y",0);
set("z min",0);
# Substrate
addrect;
set("x",0);
set("y",0);
set("z max",0);
# FDTD Region
addrcwa;
#addfdtd;
set("x",0);
set("y",0);
addmesh;
set("dx",10*nm);
set("dy",10*nm);
set("dz",10*nm);
### Source
addplane;
set("x",0);
set("y",0);
set("z",zmin_cell);
### Monitor
addpower;
set("x",0);
set("y",0);
### Parameter Sweep
addsweep;
para_h = struct;
# define results
result_1 = struct;
result_2 = struct;
addsweep;
para_r = struct;
addsweepparameter("cylinder_radius_sweep", para_r);
# define results
result_1 = struct;
result_2 = struct;
December 6, 2023 at 12:31 am
December 6, 2023 at 7:37 am
Dimitris Polyzos
Ansys Employee -
December 7, 2023 at 12:53 am
crumberger
SubscriberThanks for trying to help me with this. I see that I also cannot find an option to add an RCWA solver region under the Simulation button on the toolbar. I have just contacted someone on the server admin side to see if our organizational license is somehow set up with access to the FDTD solver but not the RCWA solver (not even sure if that's possible, but it could explain the issue if so).
Thanks again,
Charles
- The topic ‘Troubleshooting a couple of errors in Lumerical scripting’ is closed to new replies.
