September 26, 2024 at 7:29 pm
daniel.fachieri
SubscriberIm trying to simulate a chamber with a few plates inside. The 3d model I designed using gmsh and then generated the .msh file. But in Fluent, especially the watertight geometry workflow, when I try to import the mesh file i got the following message: Warning: no nodes readanalyzing boundary connectivity…done. But no mesh is imported. I've seen people getting problems like this they were using 2d geometries. How can I fix this? Â
September 27, 2024 at 10:25 am
Forum ModeratorIf it's a mesh file can't you just read the full volume mesh into Fluent? Otherwise try reading in the boundary mesh. Note, that will probably negate the use of the water tight workflow so you'll need to find the mesh objects in the tree and then volume mesh.Â
September 30, 2024 at 11:24 pm
daniel.fachieri
SubscriberI tried importing the full volume of a simple box into fluent but I got this error message:
Ansys.Fluent.Cortex.CortexNotAvailableException: Exception of type 'Ansys.Fluent.Cortex.CortexNotAvailableException' was thrown.
  at Ansys.Fluent.Data.SetupData.GetCommunicator(IReadLockContainer context)
  at Ansys.Fluent.Data.SetupData.ReadCaseModelInfo(IFullContext context)
  at Ansys.Fluent.Data.SetupData.ReadMeshAndModelInfo(IFullContext context)
  at Ansys.Fluent.Data.SetupData.LoadFiles(IFullContext context)
  at Ansys.Fluent.Commands.EditCommand.Execute(IFullContext context)
  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: Exception of type 'Ansys.Fluent.Cortex.CortexNotAvailableException' was thrown.
CommandName: Fluent.Edit(Container="Setup")
  at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
  at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
  at Ansys.Fluent.Commands.EditCommand.InvokeAndWait(IProtectedContext context, DataContainerReference Container, Boolean Interactive)
  at Ansys.Fluent.Gui.OpenInFluentGui.Invoke(GuiOperationContext context)
  at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
  at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction, Boolean deferredRefreshOnly) -
October 1, 2024 at 12:10 pm
Forum ModeratorTry reading it into Fluent Meshing. You might get a more diagnostic error.Â
5719
