July 17, 2024 at 12:29 pm
Raoul Abas
SubscriberHello,Â
we have trouble to run dyna mpp since our HPC is migrated from Centos to Redhat 8.8. I read the same issue in this closed post Trouble running MPP LS- DYna 10.20 on Red Hat 8.4 (ansys.com)
Is it possible for us to also get R13.1 sse2-intelmpi, each single and doube precision that recompiled with ifort 16.4.258?Â
Raoul
July 19, 2024 at 6:41 pm
igandiko
Ansys EmployeeR13.1 builds are using ifort 19 (it should say on the exe filename or d3hsp banner) so I don't think its the same issue. What error do you get? Which version of Intel MPI are you using? I would try the latest version of IMPI.Â
July 22, 2024 at 11:03 am
Raoul Abas
SubscriberThe run is stopped at very beginning and not even creating d3hsp.
I got this message:
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image        PC         Routine       Line     Source       Â
ls-dyna_mpp_s_R13  000000000771A243  Unknown        Unknown  Unknown
libpthread-2.28.s  000014E480A7CCF0  Unknown        Unknown  Unknown
libc-2.28.so    000014E47F187646  strtok_r        Unknown  Unknown
libmpifort.so.12.  000014E4807F4561  __I_MPI___intel_s   Unknown  Unknown
libmpi.so.12.0   000014E47FD83BE5  Unknown        Unknown  Unknown
libmpi.so.12.0   000014E47FD868F4  Unknown        Unknown  Unknown
libmpi.so.12.0   000014E47FD2764B  Unknown        Unknown  Unknown
libmpi.so.12    000014E47FD14BDB  MPI_Init        Unknown  Unknown
libmpifort.so.12.  000014E48079A240  MPI_INIT        Unknown  Unknown
ls-dyna_mpp_s_R13 Â 000000000041D90A Â MAIN__ Â Â Â Â Â Â Â Â Â 3794 Â lsdyna.f
ls-dyna_mpp_s_R13  0000000000417362  Unknown        Unknown  Unknown
libc-2.28.so    000014E47F121D85  __libc_start_main   Unknown  Unknown
ls-dyna_mpp_s_R13  0000000000417269  Unknown        Unknown  UnknownMPI:Â
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/ansys_inc/v232/commonfiles/MPI/Intel/2018.3.222/linx64/lib
/ansys_inc/v232/commonfiles/MPI/Intel/2018.3.222/linx64/bin/mpiexec
It seems that it can't get the correct library
- The topic ‘Trouble MPP dyna running in Redhat 8.8’ is closed to new replies.
5889
1306
