TAGGED: #Modal_Analysis, coupled-acoustics, coupled-field
June 4, 2024 at 3:41 am
Hassan.liaquat
SubscriberHi I am using coupled field modal to perform modal analysis of a strucuture inside a fluid. To define contacts manually, i am trying to select edges of structural and acoustic region seprately and defind contact type and formulation between them, but instead getting separate contact and target bodie. i get multiple to multiple contact and ansys says them must have common physics. I used named selection technique as well. But it didnt work. There is noÂ
June 4, 2024 at 8:43 am
ErKo
Ansys EmployeeÂ
Hi
It is very good you are using 2D axis., as it is newly exposed (beta) into WB/Mech.
I would not use contacts.
I would suggest to use shared topology (in Spaceclaim say) and so not to have contacts.
All the best
Erik
- The topic ‘Trouble in defining contacts’ is closed to new replies.
5764
