September 21, 2022 at 7:25 pm
aseibi
SubscriberI am trying to check the stress state in truss element, so I tried to creat an ETABLE using the sequence no. (LS,1 for stress and SMISC, 1 for forces) and was not successful. Any he
September 22, 2022 at 8:29 am
erik.kostson
Ansys EmployeeSee the help manual and go through and run example VM27 (link180) where etables are used.
September 24, 2022 at 4:10 am
aseibi
SubscriberThank you for your response. Where can I find example VW27? Â
September 23, 2022 at 12:17 am
Waled Raban
Ansys EmployeeYou can access the help manuals at https://Ansyshelp.Ansys.com and use your Ansys customer portal or licensing portal username/password.
September 27, 2022 at 9:39 pm
Waled Raban
Ansys EmployeeDoing a quick search in Ansys Help, I found these links:
- https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/ans_vm/Hlp_V_VM27TXT.html?q=vm27
- https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/ans_vm/Hlp_V_VM27.html?q=vm27
- https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/ans_elem/Hlp_E_LINK180.html
I hope this helps.
- The topic ‘Trouble defining ETABLE in Mechanical APDL 2022 R2’ is closed to new replies.
